swim
IRS 8" diff == SRA "V6", right?
hi guise
the toyota 8" IRS in the IS300 / BRZ center section is compatible with the center sections sold for "V6 and turbo 4cyl" trucks, right? I want to order a truck spool and have the tool grinder at work make me a carbide keycutter to machine the IRS c-clip grooves into it so I can run a spool instead of a welded diff
paging gordo
thanks <333
Why? Its the same shit. Also. You just cut the ends off the stub axles and rock out.
cut the ends off the stub axles and rock out?
maybe I'm retarded, but I can't picture how this is supposed to work
explain this to me like I'm five
Sledge hammer ?
You must be from somewhere like, say Alabama ?
I use a slide hammer, one little pop, and the side shafts are in your hands.
I understand cutting the little extension tips off the IS for the thicker core of the MkIII.
Shouldn't be a problem on a spool, as it probably has a through hole anyway, and nothing for the stubs to hit (if you are using IS side flanges).
I think i did that like 4 years ago. I probably borrowed the sledgehammer. Pretty sure i only owned claw hammers back then.
30 spline, from V6 should be correct.
I know the gear sets are the same.
