Spoolmk3
Od off light
Has anybody traced the od off light? Problem, mx83 does not shift back down From 3rd, has to be done manually. Probably a speed sensor, just need to know which 1. I'm getting ready to do my 1uz swap and keeping it a auto and swapping the tail shafts. I just need to make sure all the little problems are taken care of first. Od light does not come on when the button is pressed but the car will down shift. I removed the cluster and switched the od off bulb with the one above it (L) to check and the bulb was fine. Any thoughts?
Go buy yourself a fucking TSRM, and figure it out.
Guess you just havn't got the 'We don't hold hands here' concept yet.
I have one for the mk3, I'll just refer to that since it was the dominate car
Looks like just a ground switch. Trying to chase a broken wire behind the dash would suck since it came with a after market alarm that's prob the problem
LoL, yeah, right..........
The heaviest sportscar ever made.
While your at it, why don't you take your newb questions back over to StupidMania.......
Aww, such a hater. Grand tourer. Most people see turbo and rwd and assume the common. But with only about a 120lb difference between the ma70 and the mx83 I don't think it really matters.
You really are a retarded fuck.........
My car was at least 3 fat bitches lighter than my buddies mk3 last time we hit the scales...yea, it makes a difference, cuz I can ask my fat bitches to get out.
pretty sure it's slightly better than a 3000GT or an SVX, still really gay for bringing that shit in here and using "dominate" instead of "dominant," especially in a situation where neither word is appropriate.
posting iphone screencaps, using the term hater, asking questions about the fucking OD light and the auto trans... i think you meant to register at http://cressidaforums.forumotion.com/
The wiring in the ma70 and cressida isnt similar. The mk3 uses the older methods like in the x7, a6 etc. The x8 is full of newer series connectors and different wire.
I can definitely help out as I have an EWD in my brain.
Found it. Thanks for the help. Good thing I posted a electrical problem in the tech section otherwise I might have been screwed
