el_tirano
1JZ mx83 stalling issue
Hi, i got an issue with my 1jzgte non vvti in my mx83, if i accelerate slowly it will increase in rpm as it should do, if i step on the throttle the engine will pretty much die/bog down, for around a a second or two and then pick up, doesn't change with temperature or load on the engine. Any ideas?
Thanks
I know what the problem is........
Your a moron.
Same reason you didn't bother to read the rules here.
You fucked up !
Both your car, and your entry into the most hateful forum on the planet.
First: You can NOT post, or start a thread until you do an intro.
Second: We don't hold hands, if you can't figure it out on your own, you don't belong here.
See, you can do things on your own.
Good job !
whoa, did this site just help someone? for the first time ever?
