Turbocharged400sbc 0 Report post Posted March 14, 2015 1. thanks 2. im a glutton for punishment 3. no, 900+$ in nearly new welds and MT's in trade for my labor swapping his mustang drivetrain into a new chassis-free is fer me! 4. god id love too! some stockton rims with the GM bubble cap steelie's on it would look slick. problem is that im planning on popping in an 8.8 at some point and my welds are dual pattern so i can runem till i get alloy axles redrilled for the larger 4 bolt pattern. keep in mind i do plan on making the thing look like a wierd turbo buick wagon till people look closer. the turbo buick limited's had plenty of britework in all the same places...i was looking at a buick front and rear bumper on my buddy's car and seeing if i can narrow em and swap em onto the toyota to get rid of these ugly plastic/rubber things. my front bumper support is limiting my turbo filter options...fuck Share this post Link to post Share on other sites
Turbocharged400sbc 0 Report post Posted March 14, 2015 as long as it covers the rusty shifter and the hole i hacked into the console cover/tray...ill be happy Share this post Link to post Share on other sites
Gordo 0 Report post Posted March 14, 2015 I think the shifter would look better, if you just burned the car........ Share this post Link to post Share on other sites
Turbocharged400sbc 0 Report post Posted March 23, 2015 well i had some vacation time that i had to use before april...so when i finally found a brown/tan interior 83/84 cressida (brown sedan) me a buddy rented a car and drove down to South Carolina to get the 3 trim pieces that i needed....i ended up buying all 4 inner door pull surrounds, both ashtrays and the inner mirror trim triangles. only cost me $19.27 plus 120$ rental, 200$ in food and seedy motels and 150 in gas fuck you cressida i was really sad that the thing had 4 minty stainless window guards that i wanted but with no way to lower the windows without a good bit of work to remove the screws... that shits almost a tragedy since id love a set and ive yet to see any still available as new old stock. the thing was in terrific shape if any of you other poor mx63/2 bastards are looking for parts Share this post Link to post Share on other sites
Turbocharged400sbc 0 Report post Posted April 11, 2021 well gentlemen, its taken a while to get where i am now....no longer a master mekanik, now a true mekmachinist...seriously cnc waterjet is the bee's knee's for a gearhead. designed and built a few giant 3d printers so i can make some CF reinforced abs and polycarbonate parts....(working on a 7.5ft x 4ft x 4ft machine that can print the nose for a 94 cutlass.....only way to make racecars lighter....is to make em with more multi functional plastic parts) https://youtu.be/_k1h48T0Ob0 the cressida runs, found lots of electrical issues related to the older toyota stuff, mostly it doesnt like the higher current loads imposed by modern PCM's put it together without the 70mm turbo since ive gotta find a rearend solution before i go grenading something and destroying a rear quarter panel. im pretty much stuck with a custom ford 8.8 or 9 inch while making my own brackets or getting that 8,8 toyota axle bracket kit and make it work. i gotta finish my final rework of the electrical system, im replacing the toyota engine bay box with a GM fuse/relay box...mainly because you cant seriously believe id keep the toyota stuff when the GM stuff is cheaper and the relays can actually swap positions..... it now has a pretty stand alone system for the powertrain but i have the voltage issues extending inside the car as well. well anyways onto a video or two. sounds like a pissed off 2 stroke snowmobile. equal length primary and secondary headers were the right choice, sounds rowdy as hell for a 200hp/240ftlb tq NA 3800 LN3/L27 V6 here's about where i finally figured out why the pcm was killing the O2 heaters/ignoring the O2's and not going into closed loop....because of low voltage transients https://youtu.be/7qfiIgveqQw here's it running most recently before i decided to rip it apart and fix the electrical carp properly https://youtu.be/aGJe7x2z730 cross yer fingers for me that i can drive it in the next month. take care fella's, keep on wrenchin! Regards, James Share this post Link to post Share on other sites
Turbocharged400sbc 0 Report post Posted April 11, 2021 oh and i figured out where id go with the shifter.....and the boot/bezel. ill be 3d printing the bezel for the OEM center consol opening to let me run the B&M shifter with the CR maple boot. been looking at waterjetting a giant hurst pistol grip shifter handle for that subtle drag/drift smashup.... Share this post Link to post Share on other sites
Gordo 0 Report post Posted April 16, 2021 Oh, the royal piss bag, and the steel intercooling piping really makes it look, well, like shit. Pistol grip will make it look like mexican diarrhea. You will love it when rust scale starts entering that pos 'meracan pig-iron V8-2. Share this post Link to post Share on other sites
bigtoepfer 0 Report post Posted April 18, 2021 I'm currently working on putting an explorer 8.8 in my wagon. Seems to be the go to for most people. Share this post Link to post Share on other sites
Turbocharged400sbc 0 Report post Posted April 28, 2021 On 4/16/2021 at 3:59 PM, Gordo said: Oh, the royal piss bag, and the steel intercooling piping really makes it look, well, like shit. Pistol grip will make it look like mexican diarrhea. You will love it when rust scale starts entering that pos 'meracan pig-iron V8-2. i know! i think it'll be the perfect vibe. i scraped the cosmoline off my index mill and coated the pipes with it, should hold up long enough for the air filter to suck in a puddle On 4/17/2021 at 11:15 PM, bigtoepfer said: I'm currently working on putting an explorer 8.8 in my wagon. Seems to be the go to for most people. i keep looking at it. i can keep my 4 lug weld draglites. ill go through your thread and see what yer up to. i could probably 3d print a rear axle stronger than the 7.1" toyota rear i have Share this post Link to post Share on other sites
Urrik 0 Report post Posted April 28, 2021 On 4/16/2021 at 4:59 PM, Gordo said: You will love it when rust scale starts entering that pos 'meracan pig-iron V8-2. That engine probably shits enough of its oil back into the pipes to keep the inside walls well coated Share this post Link to post Share on other sites
bigtoepfer 0 Report post Posted April 29, 2021 23 hours ago, Turbocharged400sbc said: i keep looking at it. i can keep my 4 lug weld draglites. ill go through your thread and see what yer up to. I'm trying to figure out the most cost effective way to stay 4 lug on the 8.8 and it's looking like just redrill Share this post Link to post Share on other sites
Urrik 0 Report post Posted April 29, 2021 Will Thunderbird turbo coupe axles work in the explorer rear end? Those were 4x114.3 Share this post Link to post Share on other sites
bigtoepfer 0 Report post Posted April 29, 2021 might have to look in to it. Guess it depends on the length and spline count. Share this post Link to post Share on other sites
jzxseven 0 Report post Posted June 3, 2021 On 4/28/2021 at 6:57 PM, bigtoepfer said: I'm trying to figure out the most cost effective way to stay 4 lug on the 8.8 and it's looking like just redrill Dutchman axles. New, custom length and whatever bolt pattern. $400ish shipped for a pair. Share this post Link to post Share on other sites
bigtoepfer 0 Report post Posted June 3, 2021 That is a good price. Thanks for the heads up. Share this post Link to post Share on other sites
Turbocharged400sbc 0 Report post Posted June 20, 2021 Drove it Nothing fell off yet. Share this post Link to post Share on other sites
Turbocharged400sbc 0 Report post Posted June 20, 2021 Washed at coin op. Fresh fuel, new blades. Needs to be washed with scotchbrite sponges..... I have all four forward gears and reverse so my $200 transmission is functioning well enough. Peg Leg burnouts like nothing. There are still some serious odd voltage drop issues through the Toyota ignition switch. I never touched anything related to the circuit but for some reason the wipers will function even without keys in the ignition. Oh and the alternator isn't charging it looks like alternator is chooched Share this post Link to post Share on other sites
Turbocharged400sbc 0 Report post Posted June 27, 2021 I got up to at least 55 miles an hour I need to reinforce the hood latch support a bit more. Probably should have at least used my phone for GPS speed. I finally have enough tuning data to iron out a few issues with my maf table. Tried to play my Twisted Sister cassette and I believe the drive band broke. So I jammed a aluminum quarter inch tube into the broken off power antenna so I can listen to some FM radio on the blown speakers I feel like a kid again Share this post Link to post Share on other sites
Gordo 0 Report post Posted June 27, 2021 You have the mentality of one, so... Like what, none of the cheesy chevy forums want you either? Share this post Link to post Share on other sites
Turbocharged400sbc 0 Report post Posted June 28, 2021 Buick Share this post Link to post Share on other sites
Demesio 0 Report post Posted June 29, 2021 still better than the facebook "forums" Share this post Link to post Share on other sites
Turbocharged400sbc 0 Report post Posted June 30, 2021 Yea forums are still the s*** it's where the knowledgeable people are. I zip-tied the hood latch to my power steering cooler mount to keep it from lifting ....so that's pretty much fixed. Filled it with 92 octane and bumped the entire timing table. Definitely some more tuning to do but she no longer has issues recovering coming to a stop. Pretty f****** rowdy I was having so much fun that my partially completed exhaust started to fall off and then it was really loud and rowdy. So glad i welded in a dump in front of the muffler for the dragstrip. I got flagged down by a 70 year old fart wondering where the hell I found this thing at. He owned an 81 sedan new. Blocking traffic both of us sitting on the side of the road. Bullshiting for 15 minutes straight. I haven't went on the highway yet with the hood fully secured with zipties but I'm guessing this 4.10 rear gear isn't going to give me a whole lot of cruising speed without winding it out. Share this post Link to post Share on other sites
Gordo 0 Report post Posted June 30, 2021 On 6/29/2021 at 9:35 PM, Turbocharged400sbc said: I zip-tied the hood latch to my power steering cooler mount to keep it from lifting my partially completed exhaust started to fall off I'm guessing this 4.10 rear gear isn't going to give me a whole lot of cruising speed without winding it out. Neither of the first two statements surprise me, coming from someone with the mentality of a 12 year old. I run 4.56 gears, and I can cruise down the freeway at 140, and it has a lot more above that. Guessing your pos 'merican pig iron engine is just like any other 'merican pig iron engine. Share this post Link to post Share on other sites
Turbocharged400sbc 0 Report post Posted July 2, 2021 Well the thing is is I actually produce torque which means I don't need a gear that allows my tiny motor to wind out and actually push it through the air at that speed. As it is... the thing is fun as hell from a dig to 75 miles an hour. I haven't pushed it past that yet. I still need to toss my wideband in before I go pushing it too hard. I haven't driven it in forever I'm having a blast Share this post Link to post Share on other sites
