lucas
MX73 Clutch Pedal Kit
If you're doing a 5 speed swap on your MX73 chassis, you're going to need one of these. It's the only readily available clutch pedal that's a direct bolt in for the MX73 chassis requiring no modifications to the sheet metal on the car to mount it up, only some trimming on the sound deadening under the dash. The MX73 has factory mounting points that we've utilized along with a Toyota Celica ('90 -'93) clutch master for a direct bolt in fitment that clears the wiper motor in the engine bay and sits the pedal nicely in the cab. The main bracket is formed 1/8" steel and the hanging pedal arm is 1/4" steel on a 12mm pivot. We've also provided all the bolting hardware for the clutch mount and the master cylinder hook ups. We also have clutch line kits for W58 and R154 transmissions.
THIS KIT INCLUDES THE CLUTCH MASTER CYLINDER
Price: $ 186.00 --------------------------------------> MX73 Clutch Pedal Kit
god damn that is sexy. i hope my pedal fails or breaks so i can buy that. you guys make some pretty awesome shit. keep expanding that x7 catalog!!!
would it work with the x7 master cylinder? i kind of have a surplus.
