PANIC-WIRE www.panicwire.com
making moves! dope shit, nice work.
It's all I can do. More awesomeness on the way :)
i've been slinging your name around on some other forums. you need a website with pics and video's so i can link people to you.
You're looking at it. This thread is public right?
I've been working on it. I always thought the Pro cars I've worked on are advertising enough. Hmm...
maybe you should have them put a sticker of your email on their cars haha
Oh yeah good call! Time to call zokustyle.
PANIC-WIRE is closed until Monday February 10th due to this:
I've been stuck in Eugene, OR for the last 2 days and it's only getting worse. FML.
YES YES YES! All my new stuff will come with one. If any previous customers want a sticker just email me.
yeah they are but I use them for everything. Reverse lights, add ons etc.
Is your car running yet?
STICKERS ARE IN!
I did a jzx100 to x8 this week but didn't take a pic :(
Here's the latest WIP:
This is going into a proam car from WA. Brand new harness full milspec wire w/fire sleeving, Q45 TB, 3.5 bar map, GM iat, ID2000cc injectors, LQ9 ignition, AEMv2 (with my basemap), dual fuel pump control, CANbus data to Aim MXL via DTM body plugs. This one differs from my normal jig as it's set up for aftermarket intake manifold. It's made to run underneath for a cleaner look/routing :)
The other big news is I just got these:
I now support ST215 Cadina 3SGTE. If you need one of these wired into your car please ask!
Thanks,
Today's project. OEM rework JZX90 into 89 240sx plug and play with provisions for speedo and tach converter.
Run of the mill stuff really.
Here's another one:
S13 with jzx110 engine. Harness rebuilt to run jzx100 ecu and maf. This is a rework+ I guess. Many sections were questionable and replaced with new wire. As with all extensions this has completely new ecu pins. This is set up for powerfc and stock s13 cluster. As usual, all broken connectors were replaced with new. Fire sleeve was also added on critical wires that run along the hot side frame rail.
Currently doing 2 caldina harnesses ヽ(*≧ω≦)ノ
...More on that later
Man oh man you do some outstanding work. Good job sir. I will be contacting you within a couple months about my project.
