BKCressida1718
BkCressida's X8 2jzge na-t w/TT Electronics (first ever??????????????)
Not sure if I was the first one to successfully do this in a Cressida but oh well not really too concerned with that. Bought the car in 2011 with a bhg with the intentions of going 1jz vvti but all the motors in the area were greasy messes and missing stuff or too expensive. 2jzge can be had all day for <$500 all day so I said why not. I refused to go the familiar route of using the ge ecu because its either you stack piggybacks or go standalone after a while until I stumbled upon this setup on the clublexus forums. Spent the next couple of years gathering info on the setup and parts. Heres the info on the car:
Engine
2jzge engine with stock hg and harness out of a 1st Gen gs300 with brand new valve cover gaskets, seals, brand new clutch fan (from a ls400), with the EGR removed.
Brand new radiator
SS power steering line
XM 91-92 engine brackets
Turbo setup
T67 turbo kit for a 2jzgte from driftmotion.com which includes:
3in downpipe, 40mm 4 bolt wastegate (11psi spring)
2jzge Ebay turbo exhaust manifold
-10an oil drain
-3 oil feed with -4 adapter
Coilpacks and Ignitor from a 2000 Lexus gs300
1jz/2jz Map sensor
440 injectors and resistor pack from a Mk3 Turbo Toyota Supra
2jzgte Auto Ecu and IAT
AEM wideband and HKS Boost gauge
EGR blockoff plates
Spearco Replica Intercooler and custom piping
Drivetrain
W58 (non-turbo) transmission out of a '89 Supra along with driveshaft, pedals, and slave and master cylinders
2jz bellhousing and flywheel
ARP flywheel and pressure plate bolts
XTD 6 puck clutch disc and pressure plate
SS clutch line
Suspension
JIC front coilovers from a JZX81 (Toyota Chaser)
S13 swaybar links
New Driver side RLCA and axle
S13 Cusco Rear coilovers
T3 RCAs
Interior
Grey Cloth Interior
JDM Mk4 Supra 3-spoke steering wheel
Gauge Installation kit to replace clock
When I first purchased it
316094_240813405981670_100001590371089_6
After installing the suspension purchased by DiscoShit
485843_218542311596261_1195518512_n_zps7
Getting the wiring done by my boy JDMCRESS
525743_286462598137565_690343384_n_zps78
Waiting to do the IC installation
Cockpit Shot
After IC and piping Installed
1016829_414889905294833_129879100_n_zps8
After getting the exhaust installed
998582_425604654223358_2064172248_n_zpse
Car runs and idles as stock and pulls hard. This was done as a budget build so I'll probably leave it as it is for while but we all know how that power bug bites so we'll see, Next on agenda is definitely getting new wheels These were only put on to tow the car back and forth and ended up staying on so don't be too harsh lol. Those interested in the swap, I can and will answer what ever questions that may be asked.
Looks good !
But would look better if you painted the rusty horns, cam gears, and bolts on the front end.
And a supra steering wheel ?
Oh well, to each their own..........
Good work.
its been running for a while just not on the road and the piping wasn't completed. lol gordo the horns and stuff are getting swapped out. the car been sitting for almost two years bro. and whoremouth, I was referring to the tt setup. the issue I have with using the 7mgte electronics, its like buying a modern laptop/computer and running windows 95 on it. 7mgtes use mafs, most harnesses and plugs are brittle, sensors need changing, etc.
Nah will garricks was running two years ago courtesy of mark panic. Prob a few others too who can't take jzxp hazing. But congrats will be fun.
Those wheels wouldn't be so bad if you could just run a lower profile/narrower width tire,get some wheels spacer's,loose the mudflap's,and lower the suspension a little bit more.
Congrats on finishing the swap.Look's clean and mean.Fuck worrying about wheel's and shit anyways,because looks like the power bug will hit hard haha.Take any money you have and just keep putting it under the hood.
