lucas
MX73 Tranmission Cross Member
MX73 Transmission Cross Member
Need a trans cross member for that MX73? We've designed these plate type cross members to be used for motor swap with R154 and W58 transmissions but with added slotting for more adjustment of engine placement. Made from 1/4" laser cut steel, formed and plated, you'll be able to put your motor right where you want it. We've included new bolting hardware so you don't have to use the old bolts that are probably getting messed up from age and grit.
Shown with XM Urethane trans mount and stock rubber trans, not included with transmission cross member. The rubber trans mount must have a bolt spacing of 2.2" or 56mm side to side. Toyota has two trans mounts and the larger version will not fit.
Price: $ 76.00 each -------------------------> MX73 Tranmission Cross Member
