DiscoShit 0 Report post Posted July 18, 2015 Bosch is nice as an external. I use it on my corolla with a sumped tank. I bought the xrp fitting to retain the one way valve banjo bolt,Nice piece. Share this post Link to post Share on other sites
Gordo 0 Report post Posted July 21, 2015 I need to add some of the old crap here, since I think some members were not even of driving age when some of this was done. So here is the text from the now defunct Modified Mag Reader's Rides, with most updates: Engine:(updated Feb, 2012)Fully built 7MGE9500 RPM red line.TRD cams, 274 x 10.8 intake x 274 x 10.8 Exhaust.TODA Shim-under-bucket set (30% lighter than stock). Comp Cams 975 springs.1mm oversize SS valves.Ported, valve bowls bored to match larger valves.Group-A spec. combustion chambers.Custom JE 12:1 pistons on Crower rods,and Precision Products titanium wrist pins.Pistons are fully coated, ceramic domes, moly/teflon skirts.Head and block both cut .020" to bring the compression up to 12:1.Combustion chambers, valves & exhaust ports all ceramic coated.HKS old school adjustable cam gears.GReddy timing belt.FET 1mm metal head gasket.Doweled 7M crank(had to dowel pin this beast, kept ripping the flex plate off the crank with my 8500 rpm shift points when it had an auto).Clevite-77 bearings.Balanced.Custom 7 qt pan with swing door & crank scraper.Custom 15% oil pump speed-up drive.Remote oil filter.Derale oil cooler.Modified JDM NA Supra manifold,with Modified BBK 70mm throttle body.But soon to be 50mm ITBs.SARD fuel pressure regulator.K&N 9" cone filter inside custom filter housing.Pacesetter modified headers, coated by HPC,with full 80mm SS exhaust.Exhaust crankcase evacuation system.Derale dual electric fan.Kazama Fail-proof engine mounts.ATI crank dampener.CSR electric water pump on custom 7M adaptor plate. Countershaft converted to full ball/roller bearings.Drive train:Custom built W58 with close ratio 5th gear.AP Racing twin disk 7.25" clutch on 8 pound flywheel.W58 trans with C'c short stroke shifter.Driveshaft Shop custom 1-piece drive shaft.Diff:Street & Road Course - JDM helical LSD (Torsen) & 4.56 gear set.I originally had this gear set for the strip,but it feels so good on the street that they are straying in. I now use 5.3s at the strip.Electronics:AEM Infinity-6 Crane Hi-6 ignition box.Mallory 28880 CD coil (labled 'Lethal Voltage)ACCEL 300+ 8.8mm plug wires.ACCEL Tach AdaptorHKS Rev-Ad.Gauges:VDO EGT, water temp, oil pressure.Innivate XD-16 A/F meter.HKS injector pulse monitor & knock meter.Suspension:Front - JIC coil-overs with 14k x 200mm springs.Rear - JIC coil-overs with HKS 10k x 200mm progressive springs.Largus 27mm rear sway bar.Largus 27mm front sway bar. Serialnine subframe bushings.Rare Yamaha Concept edition front strut bar. With all custom control arms, and major subframe mods. MR-S electric power steering pump, and 2:1 steering quickener.Wheels/Tires:Wheels - BBS LMs, 17x7 front, 17x8 rear. Dunlop Direzza II Brakes:Sumitomo calipers & Wilwood 13.06" rotors, front, and Sumitomo calipers with 12" JZX rearsSS braided brake lines.Line Lock, with activation switch mounted in steering wheel.Other:Fluidine custom radiator, from back when they did that.Odyssey 1100 battery.Recaro Speed seats (real ones)Momo steering wheel.JDM dual bulb head lamp assemblies.To be installed as time permits:(already purchased, waiting to be installed)BMW E46 50mm ITB induction (manifold just about done)JDM Front bumper & air dam, and side skirts.Rear spoiler from some lowley Lambo GT track car.Defi Heads Up display.Brake proportioning valve. Bosch 044 pumpAdditional items on 'Want List':Drive shaft safety loop.Not on this car:Anything made by:OBX,Godspeed,Mishimoto,Megan,XTD,F1,SSautochrome,BC cams (BrianChina, Built-in-China, BratCrier?),ACT, RPS (Real Piece of Shit)Or any other part out of china or other third world countries.Never, None, Nada, Zilch ! Share this post Link to post Share on other sites
Gibbs 0 Report post Posted July 22, 2015 I thought you where going turbo Share this post Link to post Share on other sites
Gordo 0 Report post Posted July 22, 2015 Not until I have explored all the deep, dark, expensive corners of the NA realm. (or until I destroy one of my latest JE high compression pistons) Share this post Link to post Share on other sites
Gibbs 0 Report post Posted July 22, 2015 Oh well when is this thing gonna hit the street? Share this post Link to post Share on other sites
Gordo 0 Report post Posted July 22, 2015 Good question........ Share this post Link to post Share on other sites
Kyle 0 Report post Posted July 22, 2015 If I don't live to see this I'm haunting you and Alex. Fuck yAll! Share this post Link to post Share on other sites
Demesio 0 Report post Posted July 22, 2015 Eww, dont buy JE, that is gross... oh wait its going on a 7M.. Share this post Link to post Share on other sites
Gordo 0 Report post Posted July 23, 2015 JE has treated me right over the years, and they are easy to work with when I want something special. On another note, just ordered some 550 EV14 injectors from Performance Fuel Injection out of Nanton, Alberta. www.facebook.com/PerformanceFuelinjection Share this post Link to post Share on other sites
Kyle 0 Report post Posted July 23, 2015 you know the guy thast runs that place is a muslim canada transplant that uses parts bought from alibaba.com, right? Share this post Link to post Share on other sites
Okidriftjr 0 Report post Posted July 23, 2015 Jesus 5.3 gears behind a w58!!!! You must trap at 130mph in 5th gear JE makes better shit than weisco pistons!!! Unless you like awesome piston slap. Share this post Link to post Share on other sites
Demesio 0 Report post Posted July 23, 2015 JE has treated me right over the years, and they are easy to work with when I want something special. Come try the CP side... I'll make you something special Share this post Link to post Share on other sites
Gordo 0 Report post Posted July 23, 2015 Top end is closer to 165-ish with the 5.3 gears. Demesio, I'll keep that in mind, as I'd like to try a single ring grove piston like the old F1 V-10s. Share this post Link to post Share on other sites
haymaker 0 Report post Posted July 23, 2015 i have had great results with CP Share this post Link to post Share on other sites
Gordo 0 Report post Posted July 27, 2015 OK, here I go with a typical forum wet dream.......... Anyone interrested in poly blow-molded body parts ? Good point, will take small impacts without breaking. Bad point, if hit hard enough to rip, probably can't be patched like 'glass. They use this stuff on dirt oval cars (I've posted links before), and kart bodies. But now I found a company that says they will do custom stuff. First thought was for fender flares, and bumpers. Maybe even front fenders. I would not consider this stuff street/show quality, but more for a track car. Share this post Link to post Share on other sites
Tyler 0 Report post Posted July 27, 2015 A roof wing is the perfect piece for material like that, I would be down for one of those Share this post Link to post Share on other sites
NAC 0 Report post Posted July 27, 2015 BN kit rep... would be dope, just putting it out there... Share this post Link to post Share on other sites
bradlee 0 Report post Posted July 27, 2015 gordo making replica parts LOL. Share this post Link to post Share on other sites
Tbone 0 Report post Posted July 27, 2015 Rainguards because i snapped my rear passenger one in half. Share this post Link to post Share on other sites
Tyler 0 Report post Posted July 27, 2015 You could also make stronger gears for a w58 Share this post Link to post Share on other sites
Gordo 0 Report post Posted July 27, 2015 Is PVC actually stronger than balsa wood ? Share this post Link to post Share on other sites
Spoolmk3 0 Report post Posted July 27, 2015 +1 roof wing and sun roof deflector if the can do it out of smoke Share this post Link to post Share on other sites
haymaker 0 Report post Posted July 28, 2015 i like the roof wing or a bolt on lip that fits the chaser bumper nicely Share this post Link to post Share on other sites
Gordo 0 Report post Posted July 28, 2015 Probably not smoke, or any other translucent :-( Share this post Link to post Share on other sites
Gordo 0 Report post Posted August 10, 2015 Actually did something on my X8 today....... Temperarily mounted the Bosch 044 on the hanger, with a custom made compression fitting connecting it to the stock outlet tube. Used up a couple of aluminum fitting pieces to get everything to fit. An M12 to #6 AN, that had the M12 threads shortened, the hex shortened, the tapered nose of the #6 AN cut off, and the threads shortened. The other was a #6 AN female to 3/8" hose barb, that the nut was shortened, and the hose barb cut off flush with the top of the nut, then bored to match the 8mm outlet tube. The outlet tube was shortened about a half inch to make everything fit. Will be using a -011 teflon o-ring under the compression nut to seal. This was all required to get the filter sock at the same height as was the stock one. Still have to run heavier wire to it through the mount flange, and find a weather tight connector with larger pins to handle the current. Stock ones are damn small. Share this post Link to post Share on other sites
