BomBaClot
Project Grandpa Style !!!
Mk2 supra lsd differential
2jzge non vvti using this motor just for the rods, since the vvti rods snap at about 500hp ish
these......
2jz vvti aquired
Fuck w58's im a dumbass for ever considering one.
picked it up on the cheap.
also fuck aem and all of its bullshit. doing a. MS3X
And for those who are not aware here are the differences between a non vvti rod (same as gte rod) compared to a vvti rod.
As you can see the vvti rod is significantly smaller. Hence why I am going to swap the rods.
Also I will most like weigh both rods without the pistons to see what kind of weight difference just for shits and giggles
I will also be using gte pistons but remain with the na vvti head gasket for a little higher compression than a gte motor.
I love half breed engines.
I hate parts sellers who tell you they need exactly what car you have, or they can't look up the parts.
I have 3SG valves on my intake, 4AG valves on my exhaust, and a Nissan pattern shifter going on my W58.
The only rings I could find to fit my Cosworth pistons were from some Honda.
good engine combo. exactly what i'd have done in hindsight
I love half breed engines.I hate parts sellers who tell you they need exactly what car you have, or they can't look up the parts.I have 3SG valves on my intake, 4AG valves on my exhaust, and a Nissan pattern shifter going on my W58.The only rings I could find to fit my Cosworth pistons were from some Honda.
haha just doing the best I can. I want this thing to be right. and haha that is crazy!!!! and toyodiy.com ftw lol
haha yah I really wanted the vvti so I had no choice and the 2jz turbo motor is a waste of bloody money.
So this is why I did what I did.
Vvti gte rod is also the same as non vvti gte. Looks good make it happen.
thx man I appreciate it.
And yes you are correct. But believe it or not the JDM VVTI motors actually have the stronger non vvti rods.
why they did that? I have no clue.
First pic looks like huge bozo trunk wing. You should definitely move in that direction.
/\ hahaha thats actually thoughts of exhaust going out the trunk ;) lol
But just drop off the block at the machine shop this morning. should be done early next week.
and here are some more parts that wers aquired.
Be jelly gentlemen. :)
tial bov and wastegate
Toyota Gasket set ...this raped the wallet....
And a special treat for some suck my dick bitches action...lol
Well i know its been awhile since I last updated, but I have been busy with a new job and what not. But I have acquired a few interesting things and done a little work :)
Well first off is I got a small storage unit to do all my work in. I quit my job at the performance shop so had to get all my stuff out obviously.
Then I got my block, cleaned it up and painted it.
Then I gapped all the rings, put them on pistons, and put the pistons on the gte rods instead weak sauce vvti rods
Titan Motorsports billet tensioner and new pulley
Got the Megasquirt 3x put together!!!!
And then finally the crown jewel. First legitamate turbo I have ever owned.
It is the Boost Lab upgraded BW S366 Quick Response which has an 11 blade billet comp wheel. It also twin-scroll.
Bearings are on their way so I should have the bottom end together soon!
That's a big turbo, I think someone made like 600hp on a1jz with one. Nice choice on megasquirt.
How much is the rent on the storage lockers? I was thinking about renting one for use as a garage but not sure what a good rate is.
Haha yah it should be fun with minimal lag time. Yah my power goal is a minimum of 600 and anything more is just cake. But Turbo is good up to 800 with the bigger twin scroll turbine and billet wheel.
And this is a nicer place with a gated entry which requires a personal code to get in and a decentish area.
And after taxes and 24 hour access and renters insurance it comes out to about $220 a month
Garage is about 20x20
haha you'll have to redo the rear end to hold that power. our hubs only last to 450 robert discouvered that one.
I started thinking about this and I am undecided on what to do. i am considering a mk3 subframe install but that seems like a headache.....but then again since when is making cars that arent meant to go fast, go fast not a headache.
Should start stocking up on diffs though or do a locker in your current, as for the rest of the rear end it gets a little tougher if you want to fix the shit geometry and weak ass shit.
Put a solid pinion spacer in before you even bother trying to drive it. Trust me.
^ i will 2nd 3rd and 4th that. unless you plan to spend much downtime swapping diffs
Weld your rear or get a spool or whatever...but on the real. The weak link in this setup is the R154. Switch to a A340 or TH350/400 and cut your driveline breakage worries out.
At this point it looks like I may be going with a Ford 8.8 IRS. Just seems like a good idea.
And for the R154 Im gonna call a few trans specialty places and see what it would cost me to rebuild/refresh install Marlin Crwaler upgrades and cryo treat everything. If the price is to high or advantages wont be enough then I will just go with a T-56 setup.
