slow_n_low
t56 trans mount for LSx swaps?
I am unaware of any t56 trans mounts at this time.
I dont want to speak for XM because I dont know for sure, but I think the biggest reason is not having access to a T56 to prototype from.
If anyone local Portland has a t56 laying around let me know. Something might be able to happen.
That or get in touch with XM if you have one and need a trans mount.
Guest zOmBiEsTyLe
Don't want to sound like a douche or anything, but the trans mount is quite possibly the easiest mount you will ever have to make.
I used this:
http://www.energysuspensionparts.com/proddetail.asp?prod=61608
and bored the holes on the stock x90 trans mount and it lined up the shifter perfectly to the hole for the old trans. But I cut my front subframe to move the engine further back, so it may not work for you.
I was also looking at this too when I was mapping out my options:
http://www.sfxperformance.com/parts/TRD6559.htm
Weld it to the frames and set accordingly. The downside of this kit for me was because my engine was shifted back, I wouldn't have been able to pass the exhaust around them because the tunnel is a lot narrower where I had needed the bracket to sit. But depending on how your setup is it may work.
Guest Aratz
Spencer Hogg is doing another one here in Calgary in his x100. LS3 with TR6060. What exactly did you want to know about the mount? We are just customizing 3/8 plate.... zombiestyle has the best options listed above tho, if you have the extra cash.
