lucas 0 Report post Posted October 14, 2012 We've designed this bushing kit for the MX83 steering rack. The 80A Urethane is significantly stiffer than the stock rubber bushings that tend to wear over the years and loosen. It doesn't matter if it's an MX73 chassis or MX83 chassis, these bushing will fit both as long as it's an MX83 rack. Not sure? You can measure the Passenger side rack tube, an MX83 rack should be approximately 1.985" dia (49.6mm) at the bushing. Got an MX73 rack, we’ve got bushings for that as well. If you’ve already purchased the X8 rack bushings but want to swap in an X7 rack, you can just buy the Passenger side X7 bushing and keep the driver side you already have. Price: $ 48.50/ Pair link to XM------------------>MX83 Urethane Steering Rack Bushings Share this post Link to post Share on other sites
Guest THUG Report post Posted February 9, 2013 Im assuming these will work in a jzx81, just opposite sides Share this post Link to post Share on other sites
lucas 0 Report post Posted February 12, 2013 These were not tested on a JZX81 so I cant be sure. I would think they would work, but personally dont know enough to say yes or no. Share this post Link to post Share on other sites
Bowlsclubboy 0 Report post Posted February 12, 2013 If these work on a RHD mx83, they will work with jzx81 as the racks are externally the same. Just need to find an aussie who has purchased them... Share this post Link to post Share on other sites
Kyle 0 Report post Posted February 12, 2013 part numbers are the same for mx83 and jzx81 at toyota for rack bushings Share this post Link to post Share on other sites
Guest THUG Report post Posted February 13, 2013 an kyle comes with the facts. thanks kyle Share this post Link to post Share on other sites
lucas 0 Report post Posted February 15, 2013 sweet, thanks Kyle Share this post Link to post Share on other sites
