Guest Lofty
Lofty's Mark II Wannabe Shitbox NSFW
Guest Lofty
So I've been here for a long time. I bought the x8 as a Daily on a whim for 400$ with a bad trans. Turns out it was out of fluid so I filled it up and daily'd it for 4 months during winter. I was busy fucking with this bitch for too long to give it any attention after the manual swap. So now I'm going farther.
Anyways. I found a 2jzge for 375$ with 60k. Happy I waited that one out for a good deal. Needs a timing belt and some misc shit. 2jz is non vvti out of a gs300. I'll dumb some cool pics of the cress in a timeline format for the fun of it.
302391_10150317803222556_2141608581_n.jpg303077_10150317803427556_1023382075_n.jpg388830_10150530810652556_47807343_n.jpg397973_10150530810832556_326206745_n.jpg430357_10150656403952556_73824901_n.jpg
I said it was a daily...
as it is now, 100$ for the wheels and tires.
As you can see this bitch saw a lot of fucking abuse. Time to fix it all!
I changed the oil twice in one year of dailying it.
Is that good enough for you fuckers? Lol!
Lets see less vr4 content. I fucking hate shitzubishi's.
they run real good if you don't mind swapping the engine after every pull. but that's okay, there's a ton of them out there.
please no more galant pics... and go turbo what the hell is with everyone and the ge shit a auto 1j setup can be had for fairly cheap considering you are already 5spd
Every gasket available at the parts store is nice too.
thats a rear sump oil pan... sure that came out of a gs300?
What Gibbs is trying to say is your engine is from an sc. Bet the engine brackets have a z on them. I have a front sump gte pan I'll trade you if you wanna do shipping or something. Then make a piece of sheet metal for an oil return block off, and when you're ready to go turbo no drilling/tapping required.
Guest Lofty
Oh shit. Good eyes. Okay Kyle Ill probably need to do that. Ill shoot you a text. Thanks guys.
Guess the dude didn't know and either did I.
Lol text from dude " Mother of fuck lol ive been calling it a gs this whole time..."
Hahaha
Guest Lofty
Today is a good fucking day.
This motor is a BIT more of a project than I first originally thought though.
If I pull the head off can I reuse the head bolts or should I buy ARPs right away. Only reason is I'm afraid debris got into the engine when this one was sitting dormant.
here's a tip for just about anything engine related from now on, regardless of the make/model if its an integral fastener that is torqued and is under stress.
bolt = replace
stud = keep.
Guest Trevor
Do you have a realistic idea of what turbo set up you're going to go with, assuming you get that far into it?
I would think you'd want more power in that x8, but that's just me.
Guest Lofty
Holset would be fun.
I'm doing daily mode. Get the 2j in the car, make it reliable, then Mark II Conversion cause I pulled the boat anchor out of it already. Then suspension, etc. Reliable fun.
Holsets are cheap awesomeness, anyways.
Guest Lofty
Bought a 1 Piece driveshaft from Xcessive, I was originally going to go NA for a while but I might just begin to compile turbo parts as I may be buying a diesel plow truck to daily.
First world Wisconsin problems.
Guest Lofty
How the fuck do all you idiots manage to blow 7ms? I've been redlining this thing every day and I still cant get it to pop.
My temp gauge doesn't even work, and I don't give a fuck. It's never worked. This fucker WILL NOT DIE.
The broke ass inside of me needs it to die before I pull it. But it's been 2 years. I've dailied this for TWO YEARS.
Doesn't even smoke.
Anyways, got the 1 Piece driveshaft today, doesn't fit 7m/w58. Now everyone knows. I figured I'd try it just in case. It's about an inch too long.
mine ran great for 6 months, even after death gurgle. continued driving it to/from work daily with bhg until i lost cylinder compression and parked it.
Guest Lofty
I wish I still had death gurgle :(
What I did today instead of fucking with the X.
