Guest OrlandoGTE11211 Report post Posted July 20, 2012 So today while I was fabricating something underneath my hood I noticed my map sensor was just dangling around behind my intake manifold..I pulled it forward to inspect the wires and the vacuum line attached to it,now I went to start the car up and it was running incredibly shitty,were talking 10.0 AFR at idle and it just stalled out after a second of idling.I returned the sensor back to the dangling position behind the intake manifold and it runs okay again,has anyone ever had this issue before? I typed MAP or Turbo Pressure Sensor in the search bar,couldn't find anything related to this one issue. I am hoping the sensor isn't on it's way out though.I also know it's suppose to be bolted down on the intake manifold but I just don't know were. Share this post Link to post Share on other sites
bwcress 0 Report post Posted July 20, 2012 undo the vacuum line and make sure there is no condensation in the sensor or line... the sensor is suppose to be mounted with the vacuum nipple pointed down so that no moisture sits in the sensor Share this post Link to post Share on other sites
Guest OrlandoGTE11211 Report post Posted July 20, 2012 So that would explain why the sensor being pulled forward triggered the car to run like shit.I'll check it, is it suppose to be mounted somewhere on the intake manifold? or does it not have a location due to it not being placed in the original car. Share this post Link to post Share on other sites
WhoreMouth_Jr 0 Report post Posted July 20, 2012 if its running shitty and throwing 10s, its probably the reading the sensor is throwing to the ecu or lack there of wire is probably getting pinched or something idk Share this post Link to post Share on other sites
Guest OrlandoGTE11211 Report post Posted July 20, 2012 I feel like this sensor is causing other problems,I'll have to really look over it and make sure it's operating properly. I need to fix some issues before I can get it dyno tuned...which is unfortunate. Share this post Link to post Share on other sites
Guest Mitto Report post Posted July 20, 2012 The sensor is meant to be mounted on the fire wall above the intake. It does sound likes a loose wire could be causing it, hence the reason it works better while hanging. Pull the plug apart and check the connections. Have you tried using another sensor? If you have access to one of course... Share this post Link to post Share on other sites
Guest OrlandoGTE11211 Report post Posted July 20, 2012 I have someone who is willing to let me try there sensor so I will defiantly try that. Are the mounting location for the 7m map sensor the same as for a 1j? Share this post Link to post Share on other sites
Guest Mitto Report post Posted July 20, 2012 Hang on I'll see if I can dig up a pic of mine. I had a similar issue with mine, idled like shit. Checked all vac lines blah blah blah. Last idea was to check map, had a 2j one laying around, plugged that sucker in and idled like a champ. Opened up the 1j connector plug and wires were pretty loose. Share this post Link to post Share on other sites
Guest Mitto Report post Posted July 20, 2012 Here's an old pic of where mine is bolted too. I don't have one closer and don't really feel like going out in the cold just to take one photo. If you cant work it out from this photo then you don't belong near an engine bay (edit) to make it that little bit easier, follow the red vac line inside the green circle near the big red arrow. kbyenaow! BTW I googled "1jz map sensor location" and one of the first pic's I got was this. Share this post Link to post Share on other sites
Guest OrlandoGTE11211 Report post Posted July 20, 2012 Thank you,I really appreciate it.It's thundering outside right now,so I can't even go out there to bolt it down. I should move the shit in my garage and pull it in . Share this post Link to post Share on other sites
Guest bgjustin360 Report post Posted July 21, 2012 Does any one know how to check map sensors?? Share this post Link to post Share on other sites
Guest OrlandoGTE11211 Report post Posted July 21, 2012 Generally if it's not functioning properly,your AFR will be off the wall from my experience. Also if you read above you will see that bwcressida states that there shouldn't be any condensation in the vacuum line,also it should be mounted unlike mine.. But that's ghetto Jamaican engineering for you.. Share this post Link to post Share on other sites
Guest OrlandoGTE11211 Report post Posted July 21, 2012 @Mitto,why does the 2nd picture have 2 sensors circled? Lol. Share this post Link to post Share on other sites
Guest Mitto Report post Posted July 21, 2012 Second circled sensor on the wheel arch is for JZA70 digital dash turbo light from what I've read. Don't worry bout that. Share this post Link to post Share on other sites
