Guest bgjustin360
Car died now wont start
Guest bgjustin360
Sooo I wa drivin my car hit boost in like 3rd gear and then my car died. So then I went to try to start it and it turns over but won't start. It's an mx83 with a 1jzgte I checked the igntor with my buddy and that wasn't it do how do I tell if my ecu went I checked every thing so how can I tell
check spark, check fuel....
get fucked and ask tc.net.
check your efi fuse
What kind of car is it?
Guest OrlandoGTE11211
Yeah check fuel if anything,maybe your fuel pump decided to take a crap on you if you were pushing it. Cause I know once I get my tune I will give mine a month or two of torture before it goes.
Guest bgjustin360
It has a 255 in it and there is fuel just no spark and I checked all the fuses. And my igtior is good so how do you check if an ecu is bad??
open it up, look/smell it
not hard to miss
Borrow a friends ECU?
Guest bgjustin360
I also looked inside the ecu and it didn't smell. So what could make my car not have spark
dont borrow a friends ecu. put your ecu into a friends car. if there is something wrong with your car electronically which caused your ecu or other component to go bad, your electrical system will do the same thing to your friends component.
hit boost and died? MAP sensor. manifold backfire or fuel vapor or other contaminant into MAP killed it.
Guest bgjustin360
How do I check the map sensor?? And I can't put in friends car he went standalone and just has an extra but it didn't smell and yes i am from the 360 area code
Guest bgjustin360
I like how this guy speculates how long his fuel pump is gonna last in a car he didnt build.
Op, how long has your car been running swapped?
Guest bgjustin360
Month and a half. But I just put the 255 in it a week and a half ago.
Guest LuxurySlider
Nice im from snohomish we'll have to meet
Up when my x7 is done.
Guest bgjustin360
Yeah I'm sure we could do that. I tryed a map sensor from my buddy's 2j and that didn't work so whAt could it be now??
