Guest Dan81 Report post Posted May 14, 2012 Can anyone tell me if this fit x81 rear knuckes? http://www.buyhardrace.com/product/hardrace-rear-knuckle-bushings-connect-to-rear-lower-arm-is200-is300_100.html Share this post Link to post Share on other sites
Stephen 0 Report post Posted May 15, 2012 Hizoku on here figured out what works for spherical shit, i would pm him and use that. Share this post Link to post Share on other sites
aphxero 0 Report post Posted May 15, 2012 http://www.xcessivemanufacturing.com/ONLINESTORE.html?cid=48&step=4&pid=265 Share this post Link to post Share on other sites
HIZOKU 0 Report post Posted May 17, 2012 Yeah i worked out nothing atm. Z70 supra ones are 2MM to small But there are so many aftermarket ones out there for like IS300 JZA80 and FC3S RX7 and so on and so on. something has got to fit if you want a solid rear end. Share this post Link to post Share on other sites
rayray 0 Report post Posted May 17, 2012 hey mark, do you have these installed on your x8? or can anyone who HAS them installed give some feedback? it's really the only thing keeping me from getting these. my cressida is my daily so reliability would be a HUGE factor lol Share this post Link to post Share on other sites
HIZOKU 0 Report post Posted May 17, 2012 I have nothing to do at work so i will post here what i find while searching Share this post Link to post Share on other sites
Guest Dan81 Report post Posted May 17, 2012 was just wondering do the sxe10 ones fit as a local shop here stocks them, if they dont i'll just order some xm ones Share this post Link to post Share on other sites
HIZOKU 0 Report post Posted May 17, 2012 There are nissan ones out there that are same spec as A70 ones im trying to find out if any are a tad bigger then that will open up heaps of options Share this post Link to post Share on other sites
Mitch 0 Report post Posted May 18, 2012 I run the XM, and have for almost a year. Daily driven and well over 35k miles, still feels like the day I put them in. Share this post Link to post Share on other sites
HIZOKU 0 Report post Posted May 19, 2012 XM should have made the bushes BLACK and i would buy a set to match the other XM bushes i have. Anyway http://www.whiteline.com.au/product_detail4.php?part_number=W62996 This nissan one is very close 2MM wider but OD is the same as X8 so grind off 1MM each side of the spacers and it should fit NOW question is anyone know bolt size? http://www.splparts.com/chassis-Z33.html#SPLRKBZ33 as these then could be made to fit very easy if bolt hole is the same. downside need to buy it in a KIT unless they sell sep? Share this post Link to post Share on other sites
HIZOKU 0 Report post Posted May 19, 2012 And my mistake the SPL items are for the knuckle end not the INNER one. Share this post Link to post Share on other sites
Big Fuckin Shooter 0 Report post Posted August 1, 2015 Anyone ever figure out what else will work? Share this post Link to post Share on other sites
ROBAPHENT 0 Report post Posted August 4, 2015 XM and guy in aus called Troy sell them now Share this post Link to post Share on other sites
Okidriftjr 0 Report post Posted August 4, 2015 Who really buys bushings based on friggin color? What are you a F and F fanboi? Don't forget the under glow kit. Share this post Link to post Share on other sites
Gordo 0 Report post Posted August 7, 2015 You should see the LED lighting I have in the interior, and trunk. Kind of looks like the nova in the movie Repo Man. Share this post Link to post Share on other sites
WhoreMouth_Jr 0 Report post Posted August 11, 2015 Under glow is making a comeback just like this thread Share this post Link to post Share on other sites
