Layzorbeemz
Engine - 1JZ-GTE Idler pulley replacement.
Okay, I've been searching around the interwebs trying to find a New idler pulley for my 1JZ... driftmotion only sell's a 2JZ which doesn't fit the same unless you grind down the arm because the 2JZ belt is 1/2" longer than a 1JZ. I have read I think on poopramania that you can take the 2JZ pulley itself and swap it onto a 1JZ idler pulley arm... anyone done this?
Or does anyone have a good condition pulley I can buy?
tc.net bitch
You can replace just the idler pulley and bearing. I don't know the part #, but I know it's available. Check your local industrial bearing shop. You can probably take them the pulley/bearing and they should be able to get you one. Either that or get a 2J one and make it work.
5 seconds on google and i found this. http://www.toymods.org.au/forums/tech-conversions/25374-1jz-belt-tensioner-idler-pulley-bearing.html
i charge a rate of 75/hr for my work. 5 sec = $0.10.
you owe me $0.10 and i want it now.
if you have a plastic pulley and need to replace it, get this http://www.endevourengineering.co.nz/1jz-2jz-gilmer-pulley-kit.-xidp390397.html
I already found that thread yesterday ray ray, that's why I didn't ask about a bearing because I already found out which one it is. I am just going to go find that bearing somewhere and get a 2j pulley or some shit.
