Guest LuxurySlider
Building my shit thread
Guest LuxurySlider
So i finally got all my pictures uploaded, so i thought i would share my build with
you guys. I picked this thing up with a sloppy, leaky 5m and figured i needed to get it the
fuck out before i go broke from just buying oil.
This is what it looked like when i got it with the stock 5m.
rear by msw1991, on Flickr
hid by msw1991, on Flickr
Car sat for a few months while i waited to get some cash saved up so i could buy my friends 2jz that
he pulled out of an 93 Aristo. Got an R154, lightweight flywheel, spec stage 3 clutch, bellhousing, and xccessive mounts so i could @ least get the motor in..
bay3 by msw1991, on Flickr
bay by msw1991, on Flickr
Then beat the shit outta the firewall to get the twins to fit.
twins by msw1991, on Flickr
Got the fmic deliverd and that just got mounted.
imagejpeg_2_7 by msw1991, on Flickr
imagejpeg_2_8 by msw1991, on Flickr
Now this week im pulling the motor back out to clean up the engine to get ready for seals and also sanding the shit outta the bay for painting.
Sup dude, this is Dustin, the chickenfucker that bought the 5m and w58 over the weekend.
Good luck on the car, that's a long, dark, road!
Why you put the intercooler where it gets zero flow?
Guest Gaijin Smash Wayhoff
Kyle, everyone knows intercoolers are just for looks...
Should be fun when it's done. Looks like a nightmare in the engine bay right now.
Guest LuxurySlider
Well that's the only intercooler I could find with center outlets and the right dimensions.
Thinkin I need to cut some incognito holes in that bumper there.
slid it up, i promise you it will make a difference
Guest LuxurySlider
That thing has no room to move whatsoever the
Piping will just perfectly fit under the headlights.
Guest LuxurySlider
I decided i wanted to paint the bay so it was now or never while the motor
was out getting new seals.
Here it is after about 2 gallons of super clean and a few hours of scrubbing.
IMAG0464 by msw1991, on Flickr
IMAG0466 by msw1991, on Flickr
And after the couple hours of scotch briting.
IMAG0467 by msw1991, on Flickr
Final Product (its more of the cream color in person NOT WHITE!!)
imagejpeg_2_9 by msw1991, on Flickr
Front Mount!!!!
578374_10150815440431181_696381180_12262832_876060707_n.jpeg by msw1991, on Flickr
why not just leave it its factory color it looked good all cleaned up
Guest DuaxMachine
Because white looks so much worse when it gets dirty, that you are forced to clean it, or it will look like the typical 240 engine bay.
yea i dont get the whole painting the bay thing any car ive ever put a motor in with the exception of maybe 2 i just clean the bay and it usually looks great
Joe, be real. Sure it works, but that bumper has to be a huge obstruction to that thing. I had mine on the x8 like that when I first got it running, then flipped it so the majority was right behind the grill high mount style. After beating the car, then feeling the thing with my hand, it was considerably less heat soaked.
i also run 3" pipes and i have never felt it get hot. Ill check it next time im beating on her tho. But think about it if the case was the bumper blocking the air the damn radiator wouldnt get any either in the whole midsection. The air flows around that shit
The radiator is much larger in comparison. But that's besides the point. I understand that air flows around that. But I also understand from first hand experience that putting it in direct airflow made a huge difference to the touch. This was during a summer of nothing less than 107* days.
Feeling how warm it gets after you beat on it will do nothing for you unless you can compare it to how it is in a different location, so don't waste your time.
I suppose that's true. But all I'm saying is I have no issues. But how would I know. Maybe ill run without a bumper for a little while and see if I notice a difference.
Its still obviously doing its job, but I think the bumper in front of it is negligable. 60mph winds are going to find their way in. But I would love to be proven wrong
Log iat's with your emanage. Hell, you could prob tap the iat signal wire with something from the zeitronix and log that way if your Emanage doesnt
If I remember right, the higher the heat, the lower the voltage is. Double check that though.
Guest I<3BlondeGirls
your cream came out better than mines.
But then again you seem to have a lot more space to work than I did.
