The Chubby Chaser 0 Report post Posted February 29, 2012 I finally got a single turbo setup for my x90! Here is the setup I plan on running: -Driftmotion rebuilt 60 trim ct26 -HKS 256/256 cams -JDM 2J 440cc Injectors -R33 GT-R Fuel Pump -Gizzmo Intelligent Boost Controller -Power FC w/ Hand Controller I contacted Touge Works, the tuning division of Touge Factory in Chicago, and said I wanted to get the car tuned for 350-400hp with this setup. They replied back that 440s won't be big enough to meet my goal. I have read that the stock 370s maxed out are good for 420hp. I have also seen 1JZs make over 400hp with 440s. So, should I trust the tuner, or tell them they are fucking stupid and have it tuned with the 440s? Share this post Link to post Share on other sites
JimmyHoffa 0 Report post Posted February 29, 2012 I wouldn't bet on 370s being safe at 400 rwhp. They might do it pushing your duty cycle above 90% and with your fuel pressure jacked to the moon but it would not be good practice. According to the standard injector sizing calcs you should have 525cc/min flow to safely fuel 400 hp at 80% duty cycle. You can probably hit 400 with 440s, but if you're going to do it, you might as well do it right the first time and at least get a set of 550s for extra peace of mind. It's not like they cost as much as a new bottom end. Share this post Link to post Share on other sites
bippu 0 Report post Posted February 29, 2012 If an injector kicks into static (which is a strong possibility) kiss your engine goodbye. That being said, I would tune it for you with 440cc, I just wouldn't run it past 85-90% fuel duty, and I would set a fuel cut just incase you decided to be a dumbass and try to run more boost. Also depends on how rich your tuner wants to run the car. I don't like running cars pig rich because it's inefficient and washes out the rings. Share this post Link to post Share on other sites
aphxero 0 Report post Posted February 29, 2012 As a tuner id go 550. As a cheap ass I'd do the 440. But srsly, 440 is okay for 350. 400 not so much. And how are you controlling boost with that setup? What's your ecu? Share this post Link to post Share on other sites
The Chubby Chaser 0 Report post Posted February 29, 2012 I will be using a Gizzmo IBC and Apex'i Power FC. Share this post Link to post Share on other sites
bippu 0 Report post Posted February 29, 2012 As a tuner id go 550. As a cheap ass I'd do the 440. But srsly, 440 is okay for 350. 400 not so much. And how are you controlling boost with that setup? What's your ecu? I ran 380whp on my GS with the stock 440cc injector...through an auto. Like I said, it depends how rich your tuner wants to run your car. Share this post Link to post Share on other sites
aphxero 0 Report post Posted February 29, 2012 Like you said... I never said it wasn't doable I just gave my personal outlook if it were on my dyno. Personal tunes are a whole lot different than customer tunes. IMO, the guy at tf isn't being unreasonable he's being smart. Share this post Link to post Share on other sites
Guest DuaxMachine Report post Posted February 29, 2012 Go to 550s. Don't believe me, then go to RC Engineering's web-site. They have a program to figure injector size. My 1000cc injectors will only support 800 hp @ 45 psi. And make damn sure that you have enough fuel pump to flow 6 injectors at their rated flow & pressure. You would be supprized at how many people throw a look-a-like walbro 255 on 550cc injectors, and fry pistons. A true Walbro 255 HP is bearly big enough for that. Remember, you can't just jack the pressure, as pump delivery goes down as pressure goes up. Just look at the flow rates on the Walbro Distributor's web site. And the chinese rip-offs are even worse. Share this post Link to post Share on other sites
The Chubby Chaser 0 Report post Posted February 29, 2012 I will be using a stock Nissan R33 GT-R fuel pump. The RB26DETT uses 444cc injectors stock. I am basing my setup off of single turbo 1JZ setups found in the link below. A lot of them are running this fuel pump. http://www.japanese-...ory/toyota.html According to the calculators, I should be able to safely run ~325hp with 440s. That's not too shabby. Share this post Link to post Share on other sites
Guest Skitzo Report post Posted March 1, 2012 Fuck using an OEM, 15 yr old fuel pump, especially somethign from NIssan. Grab one of those Aeromotive Stealth ones. Quite decently priced and seem to be quite good. Share this post Link to post Share on other sites
Mats 0 Report post Posted March 1, 2012 I'm making over 500hp with 700cc injectors and aeromotive stealth pump. I maxed out 550cc injectors (95% duty cycle) making 450hp. Honestly i would recommend you going with 550 right off the bat and be safe. Share this post Link to post Share on other sites
The Chubby Chaser 0 Report post Posted March 1, 2012 Thanks for all the good info, gents. Skitzo, the current pump in my x9 is 15 years old and still pumping strong. I plan on testing the GT-R pump before I put it in. A part isn't junk just because it is OEM, old, and from a certain company. I have seen several cars run stock Nissan Z32 pumps without issue. The GT-R was pretty much Nissan's cream of the crop. This is clearly a budget build. I'm using a rebuilt CT26 for f#ck sake. I got offered a set of Blitz 540cc injectors for $250 plus shipping and paypal fees. Apparently they, "flow better than stock 2J 550cc injectors". What do you guys think? Share this post Link to post Share on other sites
Mats 0 Report post Posted March 1, 2012 i though 2j's had 440? Share this post Link to post Share on other sites
The Chubby Chaser 0 Report post Posted March 1, 2012 JDM 2J's have 440s. USDM 2J's have 550s. Share this post Link to post Share on other sites
Guest LuxurySlider Report post Posted March 1, 2012 Jdm 2j's are 440 Usdm are 550 Share this post Link to post Share on other sites
Guest LuxurySlider Report post Posted March 1, 2012 Lol^ had the page up for a minute Share this post Link to post Share on other sites
Stephen 0 Report post Posted March 1, 2012 regardless of what injectors you buy, invest in taking them to a reputable injector flow tester. most injectors won't actually be fully equal across the board, especially used ones. getting them tested and then adjusted to match is a really good idea. Share this post Link to post Share on other sites
Guest Gaijin Smash Wayhoff Report post Posted March 1, 2012 Apparently I've been grossly underestimating what size injector to run. I'm running single gt35 and would like to see about 400whp. I've got 650cc and 440cc injectors. According to RC Engineering, it seems like 650's are the better way to go but it seems like most people I've seen are getting reliable 380-400hp on 440's. Which would you guys go with? Share this post Link to post Share on other sites
The Chubby Chaser 0 Report post Posted March 1, 2012 According to every post above, you should run the 650s. Share this post Link to post Share on other sites
bippu 0 Report post Posted March 1, 2012 I have multiple customer cars that are running reliably 400whp with 440cc injectors. Like i said earlier, it depends how rich your tuner wants to run the car. And no, my personal tunes aren't very different than a customer tune. And FYI, i would trust a 15yr old OEM fuel pump over an Aeromotive stealth pump anyday. 3 of the 4 a1000's I sold last year failed. American made junk. Share this post Link to post Share on other sites
Guest zOmBiEsTyLe Report post Posted March 22, 2012 The tuner is also trying to protect himself, the last thing he wants is a car they tuned blew up because he was running close or at full duty cycle and wasn't able to adjust for a boost spike. Aeromotive isn't that bad, but expensive for what it is I find. why not just run a Walbro fuel pump or a Deatschwerks DW300 (320lph) and whats with the vid^? Share this post Link to post Share on other sites
Kyle 0 Report post Posted March 29, 2012 Hey chubs you ever dyno the kit? I was gonna get that off him, but decided that it wouldn't meet my needs. Curious to see what you get out of it, and also curious to see how it acts with the cams. Share this post Link to post Share on other sites
The Chubby Chaser 0 Report post Posted March 29, 2012 Nope. I've hit a big wall because I'm out of funds at the moment and don't want to rack up debt. Share this post Link to post Share on other sites
Kyle 0 Report post Posted March 29, 2012 That sucks man, let us know how it works out. Share this post Link to post Share on other sites
