white_raven 0 Report post Posted October 17, 2011 I need the wiring diagrams for x7! lmk if you've got one or if its posted online somewhere thanks! Share this post Link to post Share on other sites
Foompla 0 Report post Posted October 17, 2011 What do you need. Share this post Link to post Share on other sites
white_raven 0 Report post Posted October 17, 2011 body harness plug the one that comes in from the engine bay sends signals to dash and the 2 next to fuse box Share this post Link to post Share on other sites
Kyle 0 Report post Posted October 17, 2011 i dont have it here. I know whoremouth posted some photos of the pages you need iirc. also, i_need_money posted a piout. i wont be able to get to it til tomorrow. If you have a multimeter and intact 5m harness you should be able to figure it out. just figure out what color wire the function you're looking for is at it's home plug, then find same color wire on body/ecu side. check for continuity between the two. time consuming, but works Share this post Link to post Share on other sites
WhoreMouth_Jr 0 Report post Posted October 17, 2011 ^^ Indeed i did i forget where but i pm'd the same ones to you ravenator. if you need specificals help pm me and I can try haha that shitty handwriting picture has both ecu plugs and both fusebox plugs explained Share this post Link to post Share on other sites
Foompla 0 Report post Posted October 17, 2011 WHICH SIGNALS? Im not taking 400 pictures. If the wire isnt included in the circuit, toyota EWD's dont show what its for, just that its there. The dash wires come out at connector c1 under the dash on the passenger side, except for the oil pressure light, which is connector B1 under the hood if I remember correctly. The round connector by the fuse box, are all power for the starter, etc. use a test light to see when its hot. The 6 pin I can get you a pinout for, mrel and others come out of that. Share this post Link to post Share on other sites
Foompla 0 Report post Posted October 17, 2011 Also, I dont know what youd need the ecm pinout for? Share this post Link to post Share on other sites
white_raven 0 Report post Posted October 18, 2011 i'll get you pics of the plugs I need! thanks! and thanks jordan for the pics I think those will be helpful! Share this post Link to post Share on other sites
white_raven 0 Report post Posted October 18, 2011 these should help Ecu Charging My shitty rendition of what the plugs are Share this post Link to post Share on other sites
WhoreMouth_Jr 0 Report post Posted October 18, 2011 C1 is yellow under you dash.. from Engine harness ---> Car/ dash C2 is White same as C1, but practically useless. I didnt use it or remove C3+ C4 both yellow by the fuse box pretty sure i grabbed injector/ignitor power from c4 if you have any questions ill go look at my wiring haha. Recently cleaned it up a little.. Still could use some love Share this post Link to post Share on other sites
white_raven 0 Report post Posted August 13, 2012 i need a 85 ewd, the 2 plugs by the fuse block and the few under the dash. please and thank you. Share this post Link to post Share on other sites
JimmyHoffa 0 Report post Posted August 16, 2012 I'll see what I can do this weekend. I have the Toyota FSM for my car, it's just out at my parents place. Share this post Link to post Share on other sites
white_raven 0 Report post Posted August 17, 2012 ^ thanks alot. Share this post Link to post Share on other sites
JimmyHoffa 0 Report post Posted August 19, 2012 So the plugs you're looking for aren't in the body electrical section of the manual. I can however give you this. Hopefully this is actually of some use. Sorry if it isn't. If I had more time I could tell you a lot of what's what in those plugs from my setup, but I'm running around trying to get ready for a trip out of town on Tuesday AM and I don't have enough time to finish a lot of the shit I need to get finished. Share this post Link to post Share on other sites
white_raven 0 Report post Posted August 20, 2012 actually this helps alot! thanks again! Share this post Link to post Share on other sites
