bloodredsrt4
4 doors, more whores
well i started this on a local forum but figure id try to redeem myself from how bad my intro went on here lol so here goes...
well not anything new on the srt.... started getting this cressida build moving so i finally brought her out of storage and to my house
then got working on getting the piece of shit 7mge and auto trans out
then got working on simplifying the engine bay and cleaning it up
then after that i finally welded up the strut towers to strengthen them and get it into pain
im waiting on my MB Battles to come back from the powder coater and im putting all the new parts on the 1jzgte and waiting on my coils and one piece drive shaft to get here.... hoping to have the car done in time for a meet in orlando on the 16th
got some work done on the motor today...
pulled the stock twins off to replace the factory "y" pipe and down pipe is a better one... they were a bitch to take off!
then finally got the new one bolted up and turbos installed on the motor again
then i figured since i had all the stock pipin off the motor why not see what a lil wire wheel on a drill would on the dirty metal and see for yourself =)
and finally the exhaust side of the motor is done and ready to go, also installed a billet cnc block off plate for the stock bypass valve since im running a tial q bov
tomorrow ill tackle the intake side and get the motor mount brackets on and then she goes in the car! =)
well i was hung over as hell today since world of beer just opened up in town lol...
so because of that i just got a couple things done on the motor today....
cleaned up the intake mani and throttle body... before...
after...
then i did some fresh cam seals, adjustable cam gears, converted to a 2jz warer pump and a new 180 t-stat
takin it day by day
welp got off work a lil early today so got some more work done on the motor.... also realized that im not gonna make my finish date of the 16th... just not enough time and money and parts are still on the way.... but it WILL be done for simply clean 3.... anywho onto the pics
got the bottom end of the motor set at TDC, lined up the cams to their indexing marks and got the timing belt on... honestly on of the easiest motors ive ever timed
then threw the lower timing cover on, alternator, all new billet pulleys from Drift Motion and wow the motor looks so good now! weird enough the serpentine belt that fits a 1jz without a/c is from a 2000 audi a4 2.8l lol.... so i guess there is a lil euro in this build after all haha
well had a couple buddies come over tonight and help me get the rest of the motor to go in
got the Xccesive Manufacturing motor mounts bolted in
then got the ACT 6 puck cluch on with a new oem flywheel and some ARP flywheel bolts then threw the r154 trans on and its ready to drop in
tomorrow its deff getting dropped in!
well..... its in!
had to put the motor in and out about 3 times to do some hammering on the trans tunnel and fire wall but its in and fits like a glove!!
the Xcessive mounts and brackets worked awesome... i mean just look at that shifter placement!
Serialnine aero and the rest of my fuel system will be here tomorrow... susp. arms, bc coils, drive shaft and seat brackets will be here wed! shits happening!!
junk yard run was a success!! found a mk3 supra so i took the clutch pedal and the shifter since mine was all sorts of fucked up... going back tomorrow for a longer throttle calbe.... also got my aero in today from Serialnine!!
and heres a lil teaser of the wheels =)
got some more shit done this weekend... picked up my wheels from Cape Customs, 2 candy teal and 2 candy raspberry =)
then Kris got me side tracked and we wanted to see what the aero would look like mocked up
then we got working on the pedal assemblies... since these cars never came 5 speed i had to get creative... i used a clutch master from a 1990 celica gts, a pedal assembly from a mk3 supra... had to drill out the holes in the clutch pedal so it would clock the pedal so the top hole would line up with an existing hole in the car
then for the gas pedal i needed a throttle cable from a mk4 supra... so where the fuck would i find one of those in the upull around here lol... so i called up toyota and and gave them that part number and the cross referenced it for me and its the same one as an sc400.... perfect cuz there was one at the upull.... scored that and the pedal assembly just incase... it fit perfect on the stock cressi pedal except for the mounting bracket for the pedal... i needed the one off the sc400 so im glad a grabbed it... got it all bolted up and bam! 5 speed x8 cressida!
my buddy shane is coming over tomorrow while im at work to knock out all the wiring for me so hopefully tomorrow i can throw some oil in it and coolant and see if she starts! fingers crossed!!
Guest DuaxMachine
Still have the 7M ?
Is the oil pan in good shape?
Want to sell it, or trade for something ?
By the way, nice work, but are you like mexican ? (the colors).
please do yourself a favor and throw that aluminum crank pully in the trash... its called a DAMPER for a reason and that aluminum PULLEY is gonna do dick but cause trouble... youd be better of with a stock DAMPER or like an ati joint or fluid damper... other then that shit looks good
really? they're that bad? i even talked to the guy at drift motion about vibration and everything with out having a dampener on it and he assured me that they " make them with precise measurements so that there is absolutely no vibration or any room for failure".... i guess i got screwed on that one lol
Its not the actual pulley that causes vibration... the crank pulley is designed to dampen vibration in the rotating assembly... a piece of aluminum doesn't do that very well
and theres a new thread about it somewhere. ATi fluidamper.
The build is looking pretty good so far man. But like BWcress said, get rid of that pulley. Put the stocker back on and till you can afford a nicer one, the stock one will be good enough.
Things started out horribly because you posted a bunch of pics of your neon that you fagged out euro Volkswagen style. The worst kind of faggotry. If you still have the neon, you're still a fag.
People don't forget.
I hate the way your text reads, like your doing something new or innovative. "I had to get creative with the clutch pedal setup". No you didnt. you had to follow step by step instructions from one of a hundred threads on how to do it. Btw, cressida updates go here first from now on. Then you copy and paste that shit to your other less important forum. On a scale of 1-10 you started out at a -3 because of your douchy style, your bro car, and your shitty intro. Then you showed us all up with your 1j and that bumped you up to about a 7 because we typically are all douches. But then bought the same wheels as me, and gayed them up by painting them two different colors, which are both fucking terrible, and brought yourself back down to a 2. But then i remembered your teal engine bay, and that brings you back to a 5, mostly because i need some of that paint for my wheels and engine bay. I guess i could give you another point for running a divorced y-pipe, but i'd have to take it away again for the aluminum crank pulley, so 5 is a good number. Im on the fence about that vinyl.
That dp is not divorced
And for all you guys that don't want to run some euro trash on your car, a 2000ish sonoma/s10 belt works to eliminate ac too.
This dude is prime candidate for name change, why wasnt that done?
BloodRedKotex?
