Layzorbeemz 0 Report post Posted August 17, 2011 I was looking at getting a true trac celica supra diff for my x7, http://rabidchimp.com/mkii-supra-82-86/drivetrain/true-trac-limited-slip-differential.html but I've heard the spline is weak on the 7.5" mk2/x7 diff. Weak enough that my 2jzgte will eat it for breakfast from what my x8 buddy is saying. Share this post Link to post Share on other sites
Layzorbeemz 0 Report post Posted August 17, 2011 Oh and try parallel parking in a tight spot on a busy street with a welded diff. My favorite passed time. Share this post Link to post Share on other sites
bwcress 0 Report post Posted August 18, 2011 i daily my welded withoout issue... either man up and spend then money on a diff or man up and deal with the welded Share this post Link to post Share on other sites
Layzorbeemz 0 Report post Posted August 20, 2011 I'm probobly going to "man up" and buy a true trac. Share this post Link to post Share on other sites
Space Case 0 Report post Posted August 20, 2011 ^ won't change much...you're still stuck with a small RnP. also 2j...id like to see that. Share this post Link to post Share on other sites
Layzorbeemz 0 Report post Posted August 21, 2011 Well what would you suggest then? I'm open to ideas. And the 2j isn't in my car yet, still need the money for all the parts I need for the swap. Share this post Link to post Share on other sites
v-nod 0 Report post Posted August 22, 2011 @Layzorbeemz, the x7 ring and pinion splines are fine... If Robert (I_need_monies) hasn't broken his yet with his 500+ whp 1j and crazy width tires than chances are you're not going to break yours. Just pick up a Weir Solid pinion spacer while you're swapping the truetrac in and you'll be good to go. There's a thread on celicasupra for what you need to do to swap the truetrac in, if I recall you can reuse most of the bearings and shit except one pair which need to be off a 4runner or something with a 50mm i.d. Share this post Link to post Share on other sites
Gizmo 0 Report post Posted September 16, 2011 Hey So. Cal. Guys where are you getting your x7 diffs welded? I want to start drifting this beast at the track and open diff is gay. Share this post Link to post Share on other sites
Guest DuaxMachine Report post Posted September 16, 2011 The last year of the X7 in Japan, some of them came with an 8" diff, just like the X8 & Mk3 Supra. But they are rare as hell, I have only ever seen a couple of them in Japan. I had bought one, but left the housing in Japan, just had the 8" LSD shipped over. Diff mounted the same way, off the top like all the 7.5" diffs. Share this post Link to post Share on other sites
Gizmo 0 Report post Posted September 16, 2011 That's interesting, I've never heard of that 8" diff. Ive seen the torsen helical differential for sale a couple times but they're usually around $450. Shit, I'd rather buy a 2JZGE for that much. Share this post Link to post Share on other sites
Cyrious 0 Report post Posted August 7, 2012 I hate to wake an old thread but I just wanted to get people's oppinions on the weir rebuild kits. Are they worth it? I was thinking about buying one to freshen my stock lsd that doesn't work any more. http://www.weirperformance.com/maxgriplsdkits.html Share this post Link to post Share on other sites
JimmyHoffa 0 Report post Posted August 9, 2012 From my luck with his solid spacer kit for my 7.5" I'd steer clear of all of all of his stuff. I paid him ~60 bucks to make my freshly assembled diff shit out 250 bucks worth of brand new diff bearings. Fun times. As far as the tru-trac discussion goes, I've got one, it's been solid, taken a ton of abuse, and is still kicking. That says a lot since before that I went through 2 diffs in pretty short order. It does burn one tire if you try to light it up when you're at full lock in hard cornering and I do prefer the feel of a clutch type, but according to most of the guys on celica-supra forums they're the toughest thing you can put in a 7.5" housing. Someone did pop one not long ago, but he was making something like 650 or 700hp out of a 2J and running sub 10 sec 1/4 mile on huge slicks. Share this post Link to post Share on other sites
