MentalStruggle04 0 Report post Posted August 9, 2011 Car: White 1991 Toyota Cressida Engine: (JDM) 1JZ-GTE 2.5L Stock Twin Turbos Transmission: (JDM) R154 5 Speed Manual Miles: Engine - ~61,000 Miles Miles: Chassis - ~122,000 Miles Exterior (7.5/10) : Super White II Interior (8.5/10) : Gray Cloth, Custom Gray/Black dash with custom Black accents Price: $4,000 **SOLD** Name: Nick C. Contact: (407)-716-4269 Location: Orlando, FL I'm moving in mid November and will not be able to take my car with me. I really don't want to do this but I have no choice - it has to go. This particular car was bought new by my family in 91 and has stayed in the family since. I'm the third owner after my uncle and my grandfather and I have had this car for 6 years now. The car runs and drives great and have put about 5,000 miles on it since the swap. I drive it daily and don't any problems with it. There's no A/C and the valve stem seals could use to be changed. It smokes a bit at idle and on startup. I had plans to have A/C so it just needs a condenser, a fan, and one wire from the compressor housing to a body plug on the chassis. I've already had the a/c lines milled down at a machine shop for clearing the power steering bracket. Around $8K put into this car. Lots of new parts. All parts listed below were installed brand new less than 5,000 miles ago. (unless specified "not new") 1JZ-GTE Engine Gaskets/Seals replaced: Both cam seals Front main seal Rear main seal Fuel Injector seals Fuel Injector O-Rings Valve Cover Gasket s Intake gaskets Throttle gaskets Oil Drain gaskets Water Pipe gaskets 1JZ-GTE Driftmotion AFPR kit with Aeromotive AFPR 2JZ-GTE Denso Fuel Pump 1JZ-GTE Driftmotion Front Mount Large Intercooler 3" Core 1JZ-GTE Driftmotion Intercooler Piping MKIII Toyota Supra Solid Engine Mounts JZX90 Engine Brackets (flipped, not new) 2JZ-GTE Water Pump (Non Hydro) 2JZ-GTE Throttle Cable 1JZ-GTE/MX83 Custom Power Steering Line 1JZ-GTE Lightweight Power steering pulley 1JZ-GTE Lightweight Alternator pulley 1JZ-GTE Lightweight Fan Pulley 1JZ-GTE Serpentine Belt 1JZ-GTE Intake Kit + Air filter 1JZ-GTE/2JZ-GTE Timing Belt Tensioner NGK BKR7e Spark plugs 1JZ-GTE Timing Belt 1JZ-GTE Thermostat Radiator Radiator Hoses Mobil 1 10w-30 Pure Synthetic Oil R154 Beech Performance Short throw shifter R154 OEM Clutch R154 OEM Pressure Plate R154 Lightweight Flywheel MKIII Toyota Supra Clutch and Brake pedal assemblies modded to fit and looks stock (not new) TRD Toyota Shift Knob Full Length S.S. Braided Clutch Line Pilot/Throwout Bearing 1JZ-GTE ARP Flywheel bolts R154 Clutch release hub washers and clips R154 Marlin Crawler Polyurethane Socket R154 Clutch Slave Cylinder Redline MT-90 Transmission Fluid JZX90 M/T ECU (not new, obviously) 1JZ/MX83 Conversion Harness service by Guy Smiley Glowshift Boost/Vac Gauge Custom Boost/Vac Gauge Mount in place of the dash clock Battery Relocated to trunk (new battery as well) "DUAL" Head Unit HD Radio, CD Player, AUX Input, USB Input (not new) Two 10" Subs in a single enclosure (not new) 760W Pioneer MOSFET Amp (not new) Most of the standard Cressida Features are fully operational (all except A/C and Cruise Control): Power Seat Belts Power Windows Power Locks Power Moonroof/Sunroof Power Seats Power Mirrors Rear Window Defrost Tilt/Telescopic Steering Wheel CD Player (Aftermarket) 6 Speaker Stereo System (plus two 10" subs in the trunk) Heater Gray Cloth Interior Power Steering Stock Aluminum Alloy Wheels (good tread left) All electronics are operational! No Dash Cracks No leaks No rust Black accented trim and vents Cressida logo custom painted under E-Brake handle Windows have black tint 18% all the way around Fog lights (turn on automatically with the headlights) Lower Valence bar doesn't sag after installing large FMIC, custom support bracket. Car is in excellent condition and very clean. Complete sleeper. Turbos pull strong! Thanks for looking. **SOLD** -Nick Share this post Link to post Share on other sites
Mo 0 Report post Posted August 9, 2011 Wow... 500 kittens died because of this posting. Share this post Link to post Share on other sites
Kyle 0 Report post Posted August 9, 2011 Fucking steal Share this post Link to post Share on other sites
MentalStruggle04 0 Report post Posted August 9, 2011 Yeah I'd like to sell it for more obviously but I need to make sure I sell it before I move. Low price for a quick sale. Title in hand as well. -Nick Share this post Link to post Share on other sites
Guest Rue Kirby Report post Posted August 9, 2011 things like this make me mad... Share this post Link to post Share on other sites
mervins 0 Report post Posted August 9, 2011 1st your to fuckin far away. 2nd I just got a ae86 3rd Im fucking broke. Share this post Link to post Share on other sites
MentalStruggle04 0 Report post Posted August 10, 2011 1st I'm sorry about that 2nd Still for sale 3rd Buy my car!! Share this post Link to post Share on other sites
Foompla 0 Report post Posted August 10, 2011 stock suspension means = fun drive to cali. Share this post Link to post Share on other sites
Kyle 0 Report post Posted August 10, 2011 Buy it foompla, stop in Dallas and by bulls coilovers, then live the dream Share this post Link to post Share on other sites
MentalStruggle04 0 Report post Posted August 10, 2011 Do it you know you want to!! Share this post Link to post Share on other sites
Mo 0 Report post Posted August 10, 2011 Buy it foompla and i'll take you to florida and you can drive it back. Share this post Link to post Share on other sites
Kyle 0 Report post Posted August 10, 2011 A road trip to the child molester/senior citizen capitol of the world in a big rig with mo sounds like fun. I dare you foompla! Share this post Link to post Share on other sites
Mo 0 Report post Posted August 10, 2011 Doooo iiiitttt! You can give me road head bahahaha! Share this post Link to post Share on other sites
MentalStruggle04 0 Report post Posted August 11, 2011 And I am sorry everyone, but the car has been sold!!!!! Share this post Link to post Share on other sites
