Guest Fidel Cashflo
WTB: 1JZ motor1! JZ Bellhousing, 1JZ Flywheel, Motor mounts
Guest Fidel Cashflo
I need some parts. Some certain ones in specific....
I need:
1JZ Auto swap harness/ecu/blahh
1JZ R154 bellhousing
1JZ Flyhweel (OEM/Aftermarket, IDGAF)
Aristo Motor Mounts
Pair of Electric Fans
Upper 1JZ radiator hose
Lower 1JZ radiatore hose
I have:
A Whole 1996 1UZ part out!
Water Pump
Timing Belt
Coolant temperature sensor
Fan Clutch Bracket
Spark Plug wires (NGK)
Intake Mani
Starter
ECU
Igniter chips
Maf $60 shipped
Cone filter BRAND NEW blue spectre
EGR valve
Pair of headers
Throttle body
Valve covers with new gaskets
AC Compressor
Underdrive pulley
Powersteering pump (NO LEAKS)
Clutch Fan
Both heads $50
Bottom end $100
PM Me. I need this stuff soon.
Guest Fidel Cashflo
I dont have anything you need as Im using it all....but how much do you want for the clutch fan?
The fan and the clutch? $25+ shipping.
