Guest THUG Report post Posted July 4, 2011 K. so took it for a drive. Just installed the turbo and stuff. Not boosting, not boosting and not boosting. keep driving and it would boost like 0.08 kg/cm2 like super late. couldn't figure it out at all. I switch the connectors on my boost controller (im using a blitz SBC by the way, the older ones) It starts to boost so im like sweet. I get the instructions on how to adjust boost and all that jazz. I set a bunch of different settings ( 4 spots to fill) and im on my way. never really floored it that hard. i just starting making boost and i would let off. in one spot i floor it and it went fucking amazing. threw me back in my seat and it was flawless (wasnt that higgh of boost, like .039 kg/cm) I take it easy after that. then try to boost some more and it bogs right down. I lay off the throttle a bit, get back on it just nice and its fine. Try to boost it and it gets that feeling like it wants to, but something is holding it back. then it would spit and backfire like crazy. I got the impression it was running super rich. Bogs down and spits after i tap the throttle a bit. I pulled a spark plug. doesn't smell like fuel or anything. Does my spark plug and gap have an effect on that right now its a NGK BCR6EGP gapped between .89 and 1.02 mm (0.035 and 0.04 inch) what plug should i run Share this post Link to post Share on other sites
aphxero 0 Report post Posted July 4, 2011 have you driven it on just the wastegate spring? Share this post Link to post Share on other sites
Zale 0 Report post Posted July 4, 2011 Go to a smaller gap like .028ish and also, double check the shaft in the turbo. My 3037s did the exact same thing when it was blown. Share this post Link to post Share on other sites
Guest THUG Report post Posted July 4, 2011 i don't think i drove it on just the wastegate spring cause the boost never went above 0, then i figured out boost controller and it started boosting good, never really going higher that 0.6 kg/cm2 I sure as fuck hope the turbo isn't blown, i don't see how it could e. bought it from buddy and it ran in his car when it was pulled. check for shaft play or what? I assume your taking 0.28ish mm lol. Are the plugs i have,good plugs? should i just regap these ones? Share this post Link to post Share on other sites
aphxero 0 Report post Posted July 4, 2011 .028 Inch = .71mm I run this gap with 17psi boost. plugs most people use 4644 (bkr7e) or 1095 (bcpr7es) Share this post Link to post Share on other sites
JimmyHoffa 0 Report post Posted July 4, 2011 BKR7E all the way. Except if it's between 5 degrees and -30 C. In really cold weather my car just fouls plugs on tight gapped BKR7E. I was running .028" gap on 15 psi with no problem, gapped them to .025 this year since I'm planning on upping the boost by a pretty good margin. Share this post Link to post Share on other sites
Jason 0 Report post Posted July 4, 2011 have you driven it on just the wastegate spring? ^^^^This. Pull the boost control contraption off and run it on just waste gate spring pressure. Make sure the waste gate is holding pressure FIRST. This trouble shoots the problem by eliminating the possibility of a broken/mistuned/misinstalled electronic boost controller. Share this post Link to post Share on other sites
Guest THUG Report post Posted July 5, 2011 well im going to gap my plugs down, cause that needs to be done first apparently lol. This gap is tooo high Share this post Link to post Share on other sites
Zale 0 Report post Posted July 5, 2011 The gap on your plugs really wouldn't stop the car from boosting. Yes, the gap is big but running it off the WG spring would be my first trial and error (after checking shaft play). Share this post Link to post Share on other sites
Guest THUG Report post Posted July 5, 2011 gapped plugs down. fixed problem. boosted fine. Share this post Link to post Share on other sites
Guest THUG Report post Posted July 14, 2011 I think im going to get new spark plugs for the car. Im still running the BCR6EGP gapped at 0.025 what plug should i be getting. the BKR7E ? Share this post Link to post Share on other sites
bwcress 0 Report post Posted July 15, 2011 thats the plug that every one and theyre mom runs in these things so yea... Share this post Link to post Share on other sites
CelicaDRIFTER 0 Report post Posted July 15, 2011 what gap would be good on a setup running 18psi with some bkr9eix plugs? mine are still at 0.030" gap. Share this post Link to post Share on other sites
iheartMX83 0 Report post Posted July 19, 2011 18 psi with your set up, id do a .025 Share this post Link to post Share on other sites
Guest ajsmoke Report post Posted July 31, 2011 changeing the plugs solve your problem ? ( I think i need a new set of spark plugs my self ) Share this post Link to post Share on other sites
