CelicaDRIFTER 0 Report post Posted August 9, 2011 7m http://store.driftmotion.com/static/i-7m1jzvalvecovergasketset.php Share this post Link to post Share on other sites
Kyle 0 Report post Posted August 9, 2011 Use a little fipg in the spots by the front of the cams too. And I think you'll like that clutch. So far I am really digging pedal feel and engagement. Share this post Link to post Share on other sites
Guest Fidel Cashflo Report post Posted August 9, 2011 Sweet well my buddy has some brand new Toyota 7M-GTE valve cover gaskets, so I'll get them off of him this week. So I was reading about people having problems running a 2JZ water pump on a 1JZ-GTE? I have the pump and I have the pulley. Is that all I need? Share this post Link to post Share on other sites
white_raven 0 Report post Posted August 9, 2011 buy the DM pulley set its cheap and comes with pulley for water pump, alt, and ps pump, and then just get a 2jzGTE water pump from toyota. Best Route err i didnt read that you already have it. yea this it. make sure the figp around the seal! Share this post Link to post Share on other sites
Guest Fidel Cashflo Report post Posted August 9, 2011 Yeah I have a GTE Pulley, but the pump is from a GE? Will it still work or do I need a 2JZ-GTE pump? Share this post Link to post Share on other sites
shakotan-aaron 0 Report post Posted August 19, 2011 Yeah I have a GTE Pulley, but the pump is from a GE? Will it still work or do I need a 2JZ-GTE pump? you need the rear housing as well as the front pump. if you get these two bits with gaskets its a breeze. i brought them new from toyota, wasnt too expensive and i know if wont fuck out or leak after 10mins of driving. 2jzge is different as far as im aware. jzz30 1jzgte or jza80 2jzgte is what your after. Share this post Link to post Share on other sites
Big Fuckin Shooter 0 Report post Posted August 19, 2011 You need the 2JZGTE Pump and matching upper water neck. The GE pump's outlet runs horizontally, so it won't work. Share this post Link to post Share on other sites
Dewback9 0 Report post Posted August 19, 2011 I like this. I like this a lot. Please continue Share this post Link to post Share on other sites
Guest Fidel Cashflo Report post Posted August 20, 2011 Wait so I need the back piece as well to run the 2JZ GTE pump? Share this post Link to post Share on other sites
CelicaDRIFTER 0 Report post Posted August 20, 2011 u need the whole 2jzGTE water pump. water pump AND rear housing Share this post Link to post Share on other sites
HIZOKU 0 Report post Posted August 21, 2011 Awesome build sort of makes me want to build one for a day to day car and to tow my POS now i sold my other x81 Share this post Link to post Share on other sites
Guest TeckniX Report post Posted August 23, 2011 Updates on this... Should make for one hell of a nice drift car - And you're keeping A/C? ha Share this post Link to post Share on other sites
Guest Fidel Cashflo Report post Posted August 23, 2011 Son, i'm in Florida. Its too dang hot down here to not have A/C in a car. I don't really care about building a "racecar"... I'll slide the car on the street more than anywhere anyways, AC/Heat is essential. Share this post Link to post Share on other sites
Guest Fidel Cashflo Report post Posted August 23, 2011 I still need to make 2 more orders, then go pick up my piping and materials for the shifter extension at ALRO Metals. Then take a measurement for my driveshaft, have that made, and get my buddy over here to help me wire this thing up. As of now, the engine is all taken apart for coating and cleaning. These twins have NO shaft play and seem to be in good shape, getting a lof of stuff sandblasted and cleaned, powdercoating a few things. Still have to finish shaving the bay and painting it. Share this post Link to post Share on other sites
Guest TeckniX Report post Posted August 23, 2011 Good to hear! Yea a/c is crucial for me - Some people don't understand it until they live in a place that's 100+deg - then it's all worth it. StreetSlidin.. nice! Share this post Link to post Share on other sites
Guest Fidel Cashflo Report post Posted August 24, 2011 So here’s the last time the engine will look like this. I started disassembling everything to clean the motor and get it ready for new parts and a new look. God, I can’t wait until I get everything simplified, there’s way too much going on here: Soo many vacuum lines, t fittings, coolant passages, and fuel lines that run together. I may just cap everything off except for the essentials and see what the dealio is. Started removing everything that was easily accessible, started throwing everything in sandwich bags and labeling them as I went. Bought some cheap Walmart tackle boxes (big clear ones with a bunch of compartments) started throwing bolts in there and labeling. Oh yeah, organization. These twins have no shaft play what so ever! I can’t wait to get these bad boys on 12psi. Won’t be too long til it receives MKIV 550’s, a tubular and a HOLSET with some standalone action. Polished one up with a wire wheel, flossin. Yeah.. That’s more like it. The motor is in surprisingly good shape, no major problems that I’ve seen, most of the harness connectors were good aside from one injector and one coilpack. But I’ll be sure to fix those with new OEM clips when I have my buddy convert the harness. Started filling the holes before I paint the bay, just need to be ground down now. I dropped off my charge pipes, intake mani, pulleys, and valve covers to get powdercoated. And just a last picture to keep your interest up. I picked up my 8 feet of 3” 0.065 wall aluminum piping, some 2.5” square tubing to make my shifter extension, and I’m still waiting on my 10 feet of 3” 0.065 wall unpolished stainless for my exhaust. Still need to make 2 more orders for the rest of my parts (final tidbits from Driftmotion) and my clutch pedal and master from CNC. Then local driveshaft and it’s time for wheelies. Share this post Link to post Share on other sites
Guest Skitzo Report post Posted August 24, 2011 While the motor is out, and if you're plannign to stick with the twins, be a good idea to get a custom dump pipe. Share this post Link to post Share on other sites
Guest Fidel Cashflo Report post Posted August 24, 2011 I'm making a downpipe, but no dump... I'm going big single within a few months Share this post Link to post Share on other sites
Guest Piner Report post Posted August 24, 2011 I know you probably all ready said somewhere in here but what single you going with? And i feel you on the A/C, Im from florida as well. Having no A/C sucks balls I don't know how I survivied driving my BLACK with BLACK leather interior E36 around for 3 years without it. Share this post Link to post Share on other sites
Guest Fidel Cashflo Report post Posted August 24, 2011 I know you probably all ready said somewhere in here but what single you going with? And i feel you on the A/C, Im from florida as well. Having no A/C sucks balls I don't know how I survivied driving my BLACK with BLACK leather interior E36 around for 3 years without it. I'm going to build a hybrid turbo using the CHRA/Exhaust housing/Exhaust wheel from an HY35 (9cm housing aka 0.63AR), and I'm going with an HX40 compressor wheel and housing. Should have fullspool around 3k and be able to make 500whp with moderate boost (18-20psi). I may go meth. Share this post Link to post Share on other sites
Guest TeckniX Report post Posted August 24, 2011 Finally some serious build pics - Keep at it. I like the idea of the HY35 hybrid. Where did you pick up the material for your shifter extension? I keep trying to find some good metal fab places that sell shit in better sizes than lowes/home depot Share this post Link to post Share on other sites
Guest Fidel Cashflo Report post Posted August 24, 2011 Finally some serious build pics - Keep at it. I like the idea of the HY35 hybrid. Where did you pick up the material for your shifter extension? I keep trying to find some good metal fab places that sell shit in better sizes than lowes/home depot I got it from a local metal supply shop, you really need 2x2 1/2" aluminum, thickest wall possible. I just got 2 1/2" square as they didnt make any 2 x 2 1/2", but its whatever I'll make it work. Should have an idea for shifter extension length soon. Probably around 7 inches. Share this post Link to post Share on other sites
Guest Fidel Cashflo Report post Posted August 25, 2011 Dang, found a 4.27 ring gear for my differential. Shits gonna ride out. Share this post Link to post Share on other sites
Browntown 0 Report post Posted August 27, 2011 i do love this build i have one of theese sitting in my yard... its so tempting just to gut my cressida and build it Share this post Link to post Share on other sites
Guest Fidel Cashflo Report post Posted August 27, 2011 That's basically what I did, I already had a game plan when I bought it though. After I gutted it there was no going back. The car was super slow before gutting it, after gutting everything.... This thing would roast tires if you punched the gas, its insane. I'm sure the 1UZ with an R154 and a 4.08 rear end would be more than enough fun for this car. Share this post Link to post Share on other sites
