Guest adavis59
zx90 Problem! Any info appreciated! Changed oil & put coil overs in ....
Guest adavis59
Hi every one,
As title says, i have a very odd problem with my Jzx90 1jz.
I put new oil and filter on the car Friday, then put it up on jack stands to start putting coilovers in.
Fitted Tien Flex Coilovers, Rolled the Guards and went for a drive Sunday arvo.
Straight away i noticed something was wrong,
vacuum on idle was normally ~25Kpa
max boost on WOT was normally ~14Psi
Now it is...
vacuum ~19Kpa
max boost ~9Psi
Car is standard besides de Cat and 3" exhaust.
No boost controller at all.
No vacuum leaks.
Doesnt blow oily smoke.
No cooler pipe leaking.
Any other ideas??????
thanks Aiden
Stock boost is usually 9-12. Is the weather getting warmer where you are? colder air = more boost unregulated. I know in the winter i was hitting 14 and spiking to 15-16 but now that its warm again i barely see over 10-12
The real problem is you're a dumb australian that can't read.
go to jzx world forums at jzx100.com
They might not cringe when they see your retarded vernacular and instantly hate you
^^ rofl simple thing is turbos are going bad I'm sure
That wouldnt explain the low vacuum guys. Cam timing could've jumped. Did the spool point move at all? Feel sluggish?
Guest adavis59
Ha what is wrong with you guys, I have put it on a couple of other forums....
Everyone seems to be saying its a vacuum leak, but im confident its not.
we have just hit winter hear so its freezing!
Guest adavis59
you deserve to be beaten with a stick
or blinker fluid may be low. it happens
LOL . Check your tire presurre, that can be why it feels sluggish.
lets stay on track. check the timing dude. You're sure its not a vac leak right?
Guest adavis59
bad muffler bearing...
do you have a some sort of point your trying to make, fool?
Guest adavis59
yeah, im sure its not a vac leak but ill keep going over them. Brought the Vac line tester home from work tonight so will give that a go.
Will check timing this weekend
just kidding. check timing and look at the wiring by the filter. the knock sensor clips are pretty flimsy. check for ecu codes too. and how much oil did you put in it?
