bwcress 0 Report post Posted May 19, 2012 Info on said control arms mitch!!! Share this post Link to post Share on other sites
Mitch 0 Report post Posted May 19, 2012 We have finished testing them (6 months DD and track) and they will be released to the public shortly. Fully adjustable with custom tension rod, it will be sold as a kit. That's all I can say for now until they go public. Share this post Link to post Share on other sites
HIZOKU 0 Report post Posted May 19, 2012 How much longer then stock are they? and what offset wheels you running in the picture? and no chassis rubbing? Share this post Link to post Share on other sites
Mitch 0 Report post Posted May 20, 2012 I am running 1 3/4" wider than stock but they go wider. My wheels are 17x8 +15, team burst spec-ish. They allow for good clearance and angle with plenty of front grip for reverse entries. Share this post Link to post Share on other sites
HIZOKU 0 Report post Posted May 20, 2012 Thanks mitch. Offset is poo but LCA length is about same as mine at full extension. hope to hear back from my guy in regards to my new tie rod ends if that all goes well i will have pictures shortly of lock Share this post Link to post Share on other sites
aphxero 0 Report post Posted May 23, 2012 XM knuckles (regular type), XM extensions, XM tension rods, MX73 rack. Just your average front end setup anyone can do. Feels great! Â Share this post Link to post Share on other sites
HIZOKU 0 Report post Posted May 23, 2012 What offset you running any wheel rubbing? Share this post Link to post Share on other sites
Keith 0 Report post Posted May 23, 2012 Inner tie rod lengths. All have rack end thread of M14 x 1.5 Â X7: Total length: 9.69" Â X8: Total length:11.18" Â JZA80 Total length: 11.89" Â '92 Corolla: Total length: 12.91" Share this post Link to post Share on other sites
Guest Gaijin Smash Wayhoff Report post Posted May 23, 2012 Mark, how much front camber are you running in that pic? Share this post Link to post Share on other sites
Guest DuaxMachine Report post Posted May 23, 2012 Thanks Keith ! Share this post Link to post Share on other sites
aphxero 0 Report post Posted May 24, 2012 Thanks keith! btw did you ever get that fitting?  So more on the alignment and stuff  Wheels are 18x9 +15 with 225/40/18 feddys -4 camber, 6.5 caster, 0 toe LCA are +15mm on each side. Share this post Link to post Share on other sites
Guest swim Report post Posted May 24, 2012 Inner tie rod lengths. All have rack end thread of M14 x 1.5 Â X7: Total length: 9.69" Â X8: Total length:11.18" Â JZA80 Total length: 11.89" Â '92 Corolla: Total length: 12.91" the moog site is wrong, JZA80 inners aren't actually that long. Share this post Link to post Share on other sites
HIZOKU 0 Report post Posted May 24, 2012 And X7 Rack it self vs x81 PPS rack the X7 rack was 30MM smaller  And that list shows X7 inner rod as smaller does that mean only the X7 tie rod end is longer then X8 as i remember reading the X7 rack was longer overall?  Aphxero Thanks for that info. your running same specs as myself wheel wise be good to see what my cut and shut knuckles get me. Share this post Link to post Share on other sites
Mitch 0 Report post Posted May 24, 2012 The X7 rack has a longer center section and a shorter housing. Share this post Link to post Share on other sites
Guest Dan81 Report post Posted June 1, 2012 Mitch what inner tie rods you running? Share this post Link to post Share on other sites
Guest swim Report post Posted June 2, 2012 I wonder if the x7 rack gives you more angle before overcentering... Â edit: nevermind I'm a retard. doesn't matter because overcentering happens before max travel on either rack. need tension rods to fix overcentering. Share this post Link to post Share on other sites
HIZOKU 0 Report post Posted June 8, 2012 Anyone know the length of JZA80 tie rods/Rack ends not the outter one inner one Share this post Link to post Share on other sites
yokotavia 0 Report post Posted June 18, 2012 so xm just released their flca and tension rod setup on their facebook page. not on the xm site yet, but man, im stoked... Share this post Link to post Share on other sites
Guest swim Report post Posted June 18, 2012 Â lol, rod ends in bending for no reason at all Share this post Link to post Share on other sites
Keith 0 Report post Posted June 19, 2012 Unless you're emotionally attached to your front ARB (I don't run front or rear), y'all should just slap on some S13 FLCA, buy TC rod brackets off some kid for $20, weld them on to your tension rod brackets and add a couple angle iron support pieces, buy cheap adjustable S13 tension rods.....and be done with it. Cheap. Clearance for angle. Everyone has spares at the track. And oh yeah, cheap. Weld on some spherical ends if you're feeling like it, but get real...who here is building an FD chassis. I have less than $200 into the rods, brackets, & FLCAs. Â I put mine through the paces, slammed it into some rumblestrips, off course'd it, etc. Held together just fine. Front end feels better than it ever has. Â That's my rambling for tonight. Share this post Link to post Share on other sites
Keith 0 Report post Posted July 5, 2012 Unless you're emotionally attached to your front ARB (I don't run front or rear), y'all should just slap on some S13 FLCA, buy TC rod brackets off some kid for $20, weld them on to your tension rod brackets and add a couple angle iron support pieces, buy cheap adjustable S13 tension rods.....and be done with it. Cheap. Clearance for angle. Everyone has spares at the track. And oh yeah, cheap. Weld on some spherical ends if you're feeling like it, but get real...who here is building an FD chassis. I have less than $200 into the rods, brackets, & FLCAs. Â I put mine through the paces, slammed it into some rumblestrips, off course'd it, etc. Held together just fine. Front end feels better than it ever has. Â That's my rambling for tonight. Â I just want to underscore this. Â My car feels so damn good now with the wider front track, solid TC rods and added angle. Night & day, really didn't think the difference would be that staggering compared to where it was already at. Â If any of you are on the fence, do it. Share this post Link to post Share on other sites
white_raven 0 Report post Posted July 5, 2012 is there any pictures showing your s13 tc rods? Share this post Link to post Share on other sites
Keith 0 Report post Posted July 5, 2012 Have you seen an S13? That's what my front end looks like. ha. Â The tension rod bracket side is the only thing "custom." And I'd be half embarrassed to show that, it looks pretty crappy but it's strong and it works. No pics really, just cut down the S13 piece and welded it right onto the X8 bracket. Braced a couple sides of it, drilled holes to be able to slide the bolt in/out, done. Took some rough measurements to try and get them close to the same on both sides but wasn't horribly concerned. The rods are adjustable, dial in the precision there. Share this post Link to post Share on other sites
white_raven 0 Report post Posted July 5, 2012 fair enough. i'll pick some up and source a pair of brackets. Share this post Link to post Share on other sites
Guest swim Report post Posted July 25, 2012 anyone relocated their rack forward? right now that's what's holding me back. with the wheels pulled forward in the well far enough to not rub at lock, the rack overcenters badly, but with the caster set to a point where it doesn't overcenter, the wheels are impossibly far back in the well. x7 rack moved forward as much as possible would be money, I feel. otherwise you've got no chance at getting reverse entry steering angle. Share this post Link to post Share on other sites
