Space Case 0 Report post Posted April 22, 2013 we'll see how far things go with knuckles and an X7 rack, might have to notch them as well. Share this post Link to post Share on other sites
fern 0 Report post Posted April 24, 2013 just did s14 rack, lca and knuckles Share this post Link to post Share on other sites
Tyler 0 Report post Posted April 25, 2013 looks like a good setup! Share this post Link to post Share on other sites
FilthyK 0 Report post Posted April 25, 2013 S14 rack? How'd you manage that? It looks amazing though! Share this post Link to post Share on other sites
ROBAPHENT 0 Report post Posted April 25, 2013 S14 rack? How'd you manage that? It looks amazing though! Remove X8 mounts weld in S14 mounts job done..... common sense must be hard to find. Share this post Link to post Share on other sites
FilthyK 0 Report post Posted April 26, 2013 Well I guess I worded that poorly. I was more interested in positioning vs x8/x7 rack and why use it over the x7 rack. Share this post Link to post Share on other sites
ROBAPHENT 0 Report post Posted April 26, 2013 Less change of blowing seals. both from what i have read seem to be around the 3 turns lock to lock depending on knuckle setup and so on. I think it is more effort then it is worth but in saying that i could have done it as i just got my stock mounts moved closer to cross memeeber Share this post Link to post Share on other sites
FilthyK 0 Report post Posted April 26, 2013 If you have access to an s14 rack/crossmember then I think it's definitely worth the effort. Just being able to move the rack forward when you do the install and having a stronger rack makes it well worth it to me. Share this post Link to post Share on other sites
swim 0 Report post Posted April 26, 2013 now all this has me second guessing myself, I'm wondering if it'd be easier for me to put a GM rack in for my swap since GM uses m14x1.5 outers too.first step is going to be measuring the travel of my x7 rack today, I suppose. Share this post Link to post Share on other sites
swim 0 Report post Posted April 26, 2013 the travel on my x7 rack is about 6", and it's 3.5 turns lock-to-lock. the most promising GM rack that I've found only has 5.75" of stroke @ 3.5 turns lock-to-lock, on the trailblazer SS rack. GM/Ford steering racks are hella easy to make crossmembers for, though Share this post Link to post Share on other sites
Gordo 0 Report post Posted April 26, 2013 No wonder your so damn skinny, 3.5 turns ?! Bet those arms are just a blur.......... Share this post Link to post Share on other sites
swim 0 Report post Posted April 26, 2013 that's out of the car I still have a stock x8 rack in my x8 and the rack bottoms out way before it gets to full travel, which is another reason why I might go to a shorter travel GM rack Share this post Link to post Share on other sites
ROBAPHENT 0 Report post Posted April 28, 2013 Stock X8 and X7 rack are very close to the same lock to lock but remember with knuckles it will shorten the distance.. I think if i was to do all this again. (i moved Stock mounts 30mm closer) and run X7 rack i would just go out and buy a real race rack http://woodwardsteering.com/ like from here. Share this post Link to post Share on other sites
ROBAPHENT 0 Report post Posted April 30, 2013 Well my issue cant move the rack forward well not a lot with out moving rack around a bit or up higher or something. Might go aftermarket rack Share this post Link to post Share on other sites
zombieslider 0 Report post Posted May 6, 2013 is this look like its going to be a lot of angle, its hitting the frame, the other side is gonna have to be notched Share this post Link to post Share on other sites
ROBAPHENT 0 Report post Posted May 29, 2013 Anyway arms re done since the purple flaked off got these all powder coated. And front cross member reset 20mm forward 10mm up and rack moved a 5 degree angle to help new position. Going to run 5MM spacers with AE92 Rack ends. Share this post Link to post Share on other sites
Bowlsclubboy 0 Report post Posted May 31, 2013 Unless they taped up those threads, you're gonna have a bad time. Share this post Link to post Share on other sites
ROBAPHENT 0 Report post Posted June 23, 2013 HAD bad time.... LOL not all of them some Share this post Link to post Share on other sites
THUG 0 Report post Posted June 26, 2013 holy angle batman Share this post Link to post Share on other sites
RetroDrift 0 Report post Posted December 30, 2014 Has anyone tried fitting s13 off set rack spacers? Share this post Link to post Share on other sites
Gordo 0 Report post Posted December 30, 2014 Retro, try it, report back........... Share this post Link to post Share on other sites
RetroDrift 0 Report post Posted January 1, 2015 Retro, try it, report back........... k will do. a couple of my s13 owner friends use them. but they bolt and weld them on so it doesnt pull the threads out. Share this post Link to post Share on other sites
