robots
Anyone tried to adapt Tilton or quatermaster clutch ?
Hmmm, couple days ago I was caught by this vid:
Here is his car project page:
http://forum.vastaheitto.com/index.php?topic=78.0
And couple vids:
To cut story short:
That guys name is Juha Rintanen. He started with SR20 in his S14 and moved to 2JZ. Loved it ever since.
As always, there is one huge BUT:
He went to US for a year and during that time broke a number of R154 boxes. Like too much for ones liking!!!
What he did in the end is he went with most expensive option - OS GIKEN OS-88 sequential gearbox.
That one box alone is like 10k+ usd.
So I was thining out my options how to get a more durable driveline for 1j/2j.
Considering both v160 and r154.
There was one thing that I thought could be done. Where I'm stationed right now its very hard to get R154 or V160.
And RB25/RB26 4WD boxes are plenty and pretty cheap. Like under 800USD/box if bought from wreckers.
Can be found cheaper if bought from some nissan guys.
More searching and NZ guys have done smth like that already:
http://forums.d1nz.com/viewtopic.php?t=27426&sid=adbfdb8a748b3dc0f4800626b66dc0b9
Converting a nissan box to suit 1jz/2jz. Use AT bellhousing from 1jz and weld it on rb box.
Flywheel would be a custom job. And we could use aftermarket RB clutch.
But I went a bit further. And thought about adapting a US made multiplate clutch.
Smth like Tilton or Quatermaster or smth else.
Get a flywheel for 2jz from say here:
http://sciontist.com/Product.aspx?c1=666&m=Toyota
Or even try to adopt a AT flexiplate. Get a 7.25size clutch.
Change clutch disk center spline section to nissan 24x1 or just get a nissan disks from tilton or other.
Use a hydralic clutch slave cylinder. Or remain with a factory nissan fork or smth.
That way you would have a pretty descent gearbox that is pretty robust and has a better shifting feel than Toyota R154. And have the option of changing the gearbox in case of gearbox death.
Another thing is, there are a lot of aftermarket gearsets available for nissan big case gearbox and even a Ikeya sequential shifter is also made for RB box.
What do you guys think ? Wanna speculate a bit about that ??
And question to all R154 users: Any gearbox kill stories ? Or headaches ?
After drifting my r154 2 -4 times a week for the last two monthes, it crunches into second, always. I hate it. Not to mention the fucking stupid amount of shifter play. But, if i switch it up, im going v161. Nearly indestructable, and costs about 2 grand for the swap minus clutch if you save up and wait for cheap parts
I just picked up my r154 so I can't offer up any good experience. Adapting an RB box sounds pretty awesome. I'm interested to know what clutches most of the jzxp members use with their r154s?
I had an ORC twin plate in my Soarer along with the r154. It never skipped a beat, and I was extremely hard on it. Buying a new ORC is expensive but worth it in my opinion. And you wont have to piss about trying to make something work.
