ASIM2JZX100 0 Report post Posted December 18, 2010 Has any one else on this fourm fitted a bosch 044 pump to their chaser jzx100, I have a problem with mine that the wires get hot and they are thick wires too and the pump is activated via a switch. Help appreciated. thanks Share this post Link to post Share on other sites
CelicaDRIFTER 0 Report post Posted December 18, 2010 are you using a relay on it? got a fuse on there? nothing grounding out? Share this post Link to post Share on other sites
Foompla 0 Report post Posted December 18, 2010 learn how to solder? no srsly, throw a relay in there. Share this post Link to post Share on other sites
bocha-05 0 Report post Posted December 25, 2010 Hi my friend, is the relay, two Bosch 044, two relays at the pumps Bosch, here's their number 0 332 019 151 Share this post Link to post Share on other sites
ASIM2JZX100 0 Report post Posted December 27, 2010 yeh I got no relays or fuses in my setup its a direct 12v setup triggered by a trip switch any one got a diagram to how I would wire the relay in? thanks Share this post Link to post Share on other sites
mr2thomas 0 Report post Posted January 14, 2011 Use the old fuel pump power wire to turn on relay. Fuse the pump. Done deal. Share this post Link to post Share on other sites
CelicaDRIFTER 0 Report post Posted January 14, 2011 ^^^ yeah, if u run off the stock power wire on the car it'll run off the stock fuel pump relay AND it'll run off the ignition swtich therefore not needing a manual switch for the pump. Share this post Link to post Share on other sites
Skin 0 Report post Posted January 29, 2011 do you reakon the stock circuit is enough to handle the standard in tank pump + two 044s? I was planning on just piggy backing of the standard pump wires to feed my other two pumps. Im using the stock pump as a surge filler Might blow fuses or get a bit hot i reakon Share this post Link to post Share on other sites
Austin 0 Report post Posted January 29, 2011 noooo... do you know how a relay works? you have 2 12v+ and 2 ground. they are paired +-, and +-. one pair is a swithc. when it sees power, it activates a switch via electromagnetic flux, and the current is free to pass. you would wire the stock fuel pump wire to the trigger side of the relay, and run a nice large gauge wire on the other two posts inline to the bosch's and stocker. you need a 4 post relay of the appropriate amperage. Share this post Link to post Share on other sites
Bill 0 Report post Posted February 3, 2011 if you had twin fuel pumps, chances are you have your battery in your trunk too. if you have a battery in your trunk, you should wire the fuel pumps to relays in the trunk, getting fused direct power to the battery. just trigger the relays from the front (fuel pump switch on switched power etc..) or use the ecu trigger, whatever. Share this post Link to post Share on other sites
aphxero 0 Report post Posted February 4, 2011 For any run longer than 3 ft on a 044 I'd use at least 14ga for the power and ground. They draw like 20a sometimes. Just saying. Share this post Link to post Share on other sites
Skin 0 Report post Posted February 4, 2011 thats aphxero, thats what i wanted to know, no way ill piggy back off stock wires, Share this post Link to post Share on other sites
