jnianekeo
JNCressida Build
So much to do in so little time?
Deadline: '10 NW Toy Run almost...
Power Goals: Whatever I can squeeze out
Intentions: Unknown
Platform:
1990 USDM MX83
Black on Maroon
No Sunroof
Non-ABS
~135K Miles
Parts Gathered So Far:
(By Memory: Probably Missing Stuff)
Engine:
Aristo 2JZ-GTE w/ Auto Trans
New OEM Timing Belt
New OEM Tensioner
New OEM Thermostat
New OEM PCV Valve
New OEM Gaskets, Seals
New OEM MKIV Water Pump & Housing
New OEM MKIV Radiator Hoses
DM Power Steering hose
DM Nuts and Bolts
DM Underdrive Aluminum Pulley Kit
NGK Iridium IX Spark Plugs
Greddy Rep Intake Manifold
Q45 Throttle Body
Power Steering Cooler
JZX81 Engine Mount Brackets
Ultra Urethane Motor Mounts
IS300 Aluminum racing Radiator
ATI SUPER DAMPER
USDM intake Cam - forgot to add this one, was the first thing installed.
Fuel Delivery:
680cc Denso Top Feed Injectors
Twin Walbro Pumps
HKS Dual Feed Fuel Rail
Aeromotive FPR
DM FPR Gauge
DM Fuel Bypass Hose
Russel In-Line Fuel Filters
Summit ?6AN Fittings
Summit Adapter Fittings
Summit -6AN SS Hose
Legend Injector Resistor Pack
Turbo Gear:
Turbonetics 62-1 T4 AR.81
Tial 44mm Wastegate
XS T4 Reinforced Manifold
3? Downpipe
3? Electronic Exhaust Cutout
3? Exhaust Resonator
4? Intake
K&N Filter
Synapse Synchronic BOV
3? Aluminum Intercooler
3? Aluminum Piping
Silicone Couplings
T-Bolt Clamps
Kaizen -4AN Feed Line
WFD -10AN Return Line
Earls Fittings
T4 Turbo Blanket
2? Exhaust Heat Wrap
3? V-Band Clamps
Drivetrain:
MKIII R154
JZ Bellhousing
DM Lightweight Flywheel
ACT EXTREME PP
ACT 6 Puck Clutch
ARP Flywheel Bolts
MCrawler Shifter Bushings
MCrawler Shifter Socket
MK3 Turbo Driveshaft
DM Full Clutch Hose
MKIII Clutch Master Cylinder
MKIII Clutch Pedal Assembly
New OEM Slave Cylinder
New OEM Clutch Hub
New OEM Throw Out Bearing / Pilot
New OEM Clutch Fork
New OEM Fork Support
New OEM Nuts / Bolts
Redline MT90 Gear Oil
ES300 Throttle Cable
Electronics / Tuning:
Mines ECU
Apexi SAFC II
Greddy Emanage Blue
Greddy 3bar Boost Sensor
Boost Solenoid
New OEM Connectors
AEM Methanol Injection
AEM Wideband
Apexi Boost Gauge
Apexi EGT Gauge
Apexi Fuel Pressure Gauge
Greddy Turbo Timer
Blitz SBC II Boost Controller
Suspension:
Megan Coilovers
T3 RCAs
Beech 300zx brake Adapters
Extended Lug Studs
15mm Spacers
Reman 300zx Calipers
Drilled/Slotted Rotors
Other Gear:
Full Grey Interior Swap
Summit Battery Relocation Kit
Proper Acrylic Shift Knob
6K Hi/Lo HIDs
Drifto Steering Wheel
Broadway Rear View Mirror
7? Panasonic DVD Player
Recaro SPG PP Seat
Sparco 5pt Harness
What?s Done:
Coilovers Welded / Installed
7M Removed
Interior Stripped
Tranny Tunnel bashed
Engine and Tranny is bolted in
Clutch Pedal Installed
Hardest, most annoying part so far was Polishing the Valve Covers and Intake Manifold. But after it was all done, it?s very rewarding J.
Currently working on the harness: Replacing Connectors, removing anything associated to TRAC, A/C, VSV, Auto Tranny, ETC. Going to wire in the Acura Legend Injector Resistor Box and clean up the harness with new conduit and tape!!!
Will try to update as I go, but for now, posting updates isn?t priority? so hang tight?
Special Thanks to Jaden, Aaron, and whoever contributes next.
Pics of what I have done so far: ENJOY!
1990 Crossmember NARROW
1989 Crossmember WIDE
interesting... another '90 with narrow style crossmember
that's a shit ton of parts man
take that crank pulley and throw it into space. fluidampr or ati, dm light pulley's cause a painful motor irritation beyond mechanical herpes.
seriously, most people have timing belt explosions or crank failures with that pulley. save yourself the trouble, at least run the stock one until it blows off and kills people.
cool build.
and lol @ the cheepy steering wheel. i actually love those wheels that come free with chinese hubs on ebay, you can get food all over em and throw them away like nothing. they always need a little hammering to get them straight tho.
HAHA we have the same turbo! Project looks proper man. Definitely an example ofwhat this forum is all about :) Really though, 5 years ago this shit was unthinkable. Now it's normal and I love it.
And Bill's right about the pulley.
CIH - Not sure 'bout drifting. just building a daily sleeper for now.
Bill - I've ran a few DM Underdrive pulleys in the past. I daily drove my 1J two years no problems w/ that pulley. I've heard of the same problem, just haven't seen it. I will definitely look into FluidDamper and ATI though. Hate to lose such an investment by a cheapo pulley. Thanks for Lookin' out.
Aphxero - Thanks for the rep. you and your bro do some crazy stuff. always fun seeing what you guys have in store. How's that Turbo working out for you?
more pics, small update.
I didnt get too much done the last few days:
Installed fuel rail
Mounted Intercooler
Re-did Radiator brackets to fit the IS300 radiator
Made a custom adapter for the TPS on the Q45 body
Bought a decent welder, Lincoln 180HD !!! Just need a spool gun now
a FEW random pics:
this is some serio eye candy. stoked to see how this all turns out.
SHE'S ALIVE!!!
Only for a few seconds because its super late and the neighbors still like me :)
I will take it for a spin tomorrow.
Thanks AGAIN Jay, AARON, and my wife.
Well, didn't make the deadline, not due to any problems, just ran out of time. Tried to save everything for the last minute and it bit us the night before.
Got most of the mechanical side of things done. I guess whats mainly left is the finishing touches and putting the interior back together.
It's easier to list whats left than to list what has been done so far:
Methanol injection install
Boost controller install
Interior
Turbo Timer
Mount Battery Box
Recaro seat
Harness bar
Exhaust / cutout
300zx brake install
Video Coming Soon!
Here are some progress pics and how she sits now:
This is not how it went in the tank (I wish). The access hole is way too small to fit like this, I had to trim the hanger and remove the rubber sleeves for it to fit.
sick man this how shit should look great job man looking forward to the vids
fuck that alot of bottle of heat in that picture
Wow, how have I not seen this thread before. Looks awesome. Can't wait to see some videos.
The car felt great. Just took it around the block. Open downpipe. No issues, didn't take it past 3k. Just my own "break in" period. But the motor wanted more. Can't wait to take it for a longer drive.
Videos are off the phone horrible quality. Will get better ones up. Turn up the sound!
Startup
build looks great ! any issues with that intake manifold where it bolts up to the stock runners? ... leak wise? i've seen people weld them up even the real greddy ones . just curious. also what's your diff. setup ? does your car have a stock lsd
