jnianekeo
JNCressida Build
Great job super clean well done
build looks great ! any issues with that intake manifold where it bolts up to the stock runners? ... leak wise? i've seen people weld them up even the real greddy ones . just curious. also what's your diff. setup ? does your car have a stock lsd
Currently running stock open rear end. Looking for an ma70 diff to put in before I turn up the power.
As for the manifold... I didn't have any problems until I opened her up on my way to work. I was probably running about 8-9psi and it felt amazing. I can definitely notice the torque compared to my 1Js in the past. But as I was mobbing away I hear a pop and then a really loud annoying whistle develop. At first I thought it was an intercooler pipe blow off, but then I noticed the whistle got louder everytime I leaned against the manifold. I notied a gap between the manifold and the runner. The plate between is aluminum so eventually they will all warp and leak. I had a horrible vacuum leak and no boost pressure. So I put my Spool gun and new new welder to work. Its my first time welding aluminum so don't hate.
Just got her done this morning. Still need to clean her up. Will try to have it back together by this weekend.
Currently running a stock fan for now: planning to do dual 12" fans soon.
Stock Cressida fan and fan clutch, or did u go with a LS400 fan clutch with a MKIII supra fan blade?
As of right now, I'm running a sc300 fan clutch and fan. Had to trim it a little to clear the upper hose. This is temporary until my fans come. In the past I've run a stock soarer clutch and fan.
