EightyOne
Building up the cresta
its been a year, still the car not yet found the road..hope to get on the road by sept..
upgrade from w58 to r154 together with OS Giken supersingle..
and also got myself a JIC Magic front coilovers..
nice and tastefull keep the viennas and use massive flares ! :D
sorry been lack of update..car now in my own porch,
finish transplant the 2j,had abit of problems, i had the car revving rapidly when i'm on 4th n 5th gear at 5k+ rpm,
might be clutch slip, or anything else..still doin troubleshooting..
Yup that is your clutch slipping just change that out and I'm sure you will be set
replaced the suspension as the stock one kinda bumpy..
also replaced the brake lines to braided as the old lines is in need of replacement..this is my previous line intended to be use on my previous 180sx..
mind the brakes,as lack of green to get a nissan 4pot..also used s13 link arm stabilizers
also replace is the servo brake pump..bleed the system and can see the shit out of it..
install the viennas..
specs are 19x9.5+18 fronts and 19x10.5+5 rears..
front with max negative camber plates doin fine, rears out by few inches..
yeah thats what i thought.. i lost the slave pump shaft and replace that shaft without knowing the correct lenght..cud it be related?
fyi, i'm using a used OS supersingle, buy it from a fren which was ok on his gearbox..
also the speed sensor is not connected yet..
yeah it can be your engagement from your pedal as well it just needs to be adjusted thats what we had to do to one of our cars
well, the car is not entirely finish,need a lil tweak but its drivable..
exhaust now only dwnpipe..wil do the pipework when time available..also looking up tidying the engines wirings..messy!
add a tad bit of camber front and back and your car will be sitting pretty
not much update but some problem with the car at the moment
last time,bought a used clutch(osgiken supersingle push type conversion on the r154) off from a fren and the clutch was working fine before he took it off..
refering from the video, is the clutch slipping in ur opinion OR izit the speed sensor connection which not connected yet?
was really hopeful that the speed connection is causing the problems and not the clutch..damnn..
That's the clutch man
sad to hear that.. :(
hav to fork out $$$ kacheng!!
car will hav more ground time for now..
strip out the interior..
doin some cleaning & wiring to make the cluster working..
too bad theres a slight difference between the car with the wiring guide by the jzxp..
or else will go this route..custom clusters..
fixed the clutch problems..replace my faulty slave pump,then turns out to be the shaft pushing the clutch fork is slightly longer to make the clutch engage when it shudnt be engage..adjusted and now runs beauty..
Work equips are wayyyyy better. I have massive problems out of my clutch slave cylinder as well. I have to rebleed every few days
o shit bro. just try not to peg that thing at 88mph or the flux capacitor will kick in yo.
