Gibbs 0 Report post Posted December 2, 2009 looking to see what drive shaft setup yall used we used the mk3 front with cress back kinda to short need to know which is the proper for use Share this post Link to post Share on other sites
JZXpwns 0 Report post Posted December 2, 2009 W58 - mk3 NA 5spd front, cressida back R154 - I think you can use the whole stock cressida shaft Share this post Link to post Share on other sites
Bill 0 Report post Posted December 2, 2009 i called up driveshaftshop.com and talked to them, gave my measurements and got a shaft made and delivered fast for not too much coin, and incredibly, it's actually balanced. Share this post Link to post Share on other sites
cocobutterz 0 Report post Posted December 2, 2009 I'm just gonna go with Driveshaft Shop and get a single piece. I was gonna go with the hybrid stock 2 piece but i ended up doing custom mounts and its off a little bit now. i'd rather go with a single piece should give it some more gusto. Share this post Link to post Share on other sites
Gibbs 0 Report post Posted December 2, 2009 well when i put it on my buddy's car i went with the supra front peice and the cres back it fits and all just a little shorter then normal so we where looking for a better fit Share this post Link to post Share on other sites
I_need_money 0 Report post Posted December 2, 2009 i used a shortend sequoia driveshaft cost me 75$ and another 100 to shorten and balance it i think its indestructable. Share this post Link to post Share on other sites
lucas 0 Report post Posted December 3, 2009 W58 - mk3 NA 5spd front, cressida backR154 - I think you can use the whole stock cressida shaft close.... w58= N/A supra front half + cressida center bearing + rear half R154= Turbo supra front half + cressida center bearing + rear half other ideas: #1... R154= extend cressida front half by 2" (the spine count and diameter of the auto matches the R154) <-- did this, works fine #2... have a solid driveshaft made using all cressida stuff Share this post Link to post Share on other sites
zokustyle 0 Report post Posted December 3, 2009 What's the difference between using a cressida center bearing and a supra center bearing? Share this post Link to post Share on other sites
Gibbs 0 Report post Posted December 3, 2009 all we did tonight was shave the e-brake bracket some and shave on the supra frot carrier bearing peice and it all works fine now Share this post Link to post Share on other sites
Hater 0 Report post Posted December 3, 2009 What's the difference between using a cressida center bearing and a supra center bearing? The supra and cressida center bearing mount up in different ways, the supra one puts the drive shaft at an awkward angle. Share this post Link to post Share on other sites
brian 0 Report post Posted December 3, 2009 i used the supra center bearing with spacers and longer high grade bolts... works perfect and is straight. Share this post Link to post Share on other sites
lucas 0 Report post Posted December 6, 2009 more than 1 way to skin a cat I guess. anyone wanna put together a photo series on the different options? Private eyes or something? Share this post Link to post Share on other sites
Guest angus Report post Posted December 11, 2011 QUOTE (JZXpwns @ Dec 2 2009, 11:14 AM) W58 - mk3 NA 5spd front, cressida back R154 - I think you can use the whole stock cressida shaft close.... w58= N/A supra front half + cressida center bearing + rear half R154= Turbo supra front half + cressida center bearing + rear half other ideas: #1... R154= extend cressida front half by 2" (the spine count and diameter of the auto matches the R154) <-- did this, works fine #2... have a solid driveshaft made using all cressida stuff Anyone simply install the R154 with stock MX83 driveshaft, I read that people have done it and it works abeit I suppose they are only getting 1/2 the spline engagement that was intended... Share this post Link to post Share on other sites
Kyle 0 Report post Posted December 12, 2011 Stop reading and start doing fucktard, til then no one gives a fuck Share this post Link to post Share on other sites
Guest DuaxMachine Report post Posted December 12, 2011 Kyle, Let him install the short driveshaft. It will fail at speed, and he won't ask such retarded questions any more, because he will be dead ! Driveshaft .5" too short, probably get away with it. Driveshaft 2" too short (like his dick) - FAIL ! Share this post Link to post Share on other sites
