Emag_dnim13
SUPER SERIAL VII
Okay so I just had a week off and it seems like a worked the whole time but don't have anything substantial to show lol Cage, gussets and the mounting plate for the pedals are fully welded in. The engine bay had a ton of this wax coating so I spent a bunch of time getting that off, Dropped the tank and cleaned it out/up put in my Bosch 044. Gerard did the other rear fender , looks like the other one lol I bought a NA 2JZ so i'm in the process of putting my head on that , I have a Borg Warner SX360 turbo coming.
This is gay .... no photos cause it just looks the same ..... Next things to do are to assemble the engine , do the front fenders and plumb the pedals.
are you using the 87-88 GX81 1g-gte 8" diff or doing something custom?
Finally some forward progression worth posting about .
I would like to thank Exedy USA for sponsoring me for the 2012 season
I still paid for this clutch I simply got it at a reduced cost to requiring me to run Exedy livery
I was going to get the Exedy Twin Carbon but after doing a bunch of research on Supraforums and direct talks with Exedy I decided on the regular Multiplate.
I collected a bunch of parts
Head gasket
Front and rear main all that boring shit
New tensioner, timing belt , serpentine belt etc
Egay manifold and 40mm Wastegate
Marlin Crawler shift leaver : ball seat and socket
In the above photo is a set of the LS400 ( MX83 ) Poly Steering rack bushings I did get them in my car but it took EXTENSIVE shaving to get them to fit in the X7 cross member with the X7 rack
So combined my old 1JZ from last year minus the turbo set up with a NA 2JZ block and the gaskets and shit and bam 1.5 JZ
The front covers are off my 1JZ That gap in between is all more displacement for this year lol
Here you can see the car now finally has the proper front camber again. I have switched back from the ``normal strut tube`` to the milled strut tubes. These have 3.5 degrees of camber milled into the knuckle and are now only 5 inches tall allowing you to go ANOTHER inch lower .
Missing something.....
It seems that Borg Warner has some sort of infinite back order so I dont know when i'll have my turbo
so in order to make Evergreen ProAm round 1 i'm just going to run a HX40 with my old down pipe.
Things that remain before Round 1 on April 21st
Mount and Plumb : E-Brake and FPR
Install Painless harness, Kill switch and battery
Alignment and Tune
shit looks fresh... i wish my front cover was clean... what did you paint the engine plastics with came out really good
sand the rough surface of the covers and you can get a nice glossy finish after you paint it
wicked setup!
Looking good Kev. Should be a good year. There is 4 cressidas, all jz powered competing in the evergreen pro am this year. If anything it sure as hell won't sound like NASCAR out there haha. Good luck.
Guest Gaijin Smash Wayhoff
Love the work and attention to detail going into this.
It could just be me but it seems like unless you're planning on running some sort of ducting or massive electric fans, that appears to be a really inefficient cooling setup.
Guest JoooeOne
what type of radiator are you using i will like to have the same set up on my x8
Thanks man
BOTH .
I have always ran fans on the rad and ducting on the intercooler , Last year I made some ducting for the rad and never once had cooling problems like i did in 2010. I like this set up do to the extremely short intercooler piping but ........
what type of radiator are you using ?
will probably change to a conventional setup if i damage the front end, It is a BECOOL radiator that has had about 8 hours of custom fab done to it. Filler cap removed ,inlet moved , converted to dual pass , an fitting and temp sensor bung welded in and mounting tabs. I'm not skilled enough to weld aluminum with the degree of skill required to make it water and pressure proof so i need to get that done. Which is either a bunch of money to get someone to do or a bunch of time getting my buddy to come do it , both of which are not ideal in the middle of my race season.
I think he wrecked this car already I think
Looks like the front and rear end both got smacked as well as a bent wheel. It's a damn shame, I was really looking forward to seeing what this thing could do this season,
