travis?
x8, 5speed swap, neutral switch wires?
finally got the god damn 5speed swap in my car, now,
which wires do i need to connect to make the starter work?
been looking around and can't find any info anywhere, fuck.
its a 91' if that matters.
kthnks
I'm still double checking, but I think there is a black wire and a black wire with a white stripe.
I believe those are the pair to tie together.
I don't have an X8, but I'm looking through some diagrams.
Look at your automatic, and you should be able to see which switch/wires were for the selector. The backup switch is usually two wires.
On the engine harness where it connects to the tranny harness There's a round grey 3 wire plug. On said plug there is a blk and a blk/white wire 14 gauge iirc. Twist them together and its all good :) If you wanna use a clutch switch you can cut the red wire (3rd pin in) from the theft ecu and put it to the clutch switch. Then ground the other side of the switch.
Have fun :)
