WhoreMouth_Jr 0 Report post Posted August 9, 2017 I've def read through that thread, especially that section a few times. The thing is I have 0 fab skills so I would be paying someone to replicate this. Share this post Link to post Share on other sites
Gordo 0 Report post Posted August 9, 2017 Too high class for the likes of us.... Share this post Link to post Share on other sites
battleaxe 0 Report post Posted August 9, 2017 A fellow supra guy on CS who isn't dumb is apalov. He has s13 front and rear suspension in his A6 and a vvti 1jz. His was a rusty dump that he made better. Could ask him as the floor is sort of similar. I'm unsure of any x7 that have done this via social media. My vote is s13 rear for available everything. X8 might also be wider than s13. I also don't like the x8 rear hub bearing situation. If you're able to grab both rears to measure side to side would give better idea for track width and your wheels. X8 positive is factory 5 lug. Though s13 is easy to do too, also factory in s14 variation. X8 does however have dual adjustment rear to narrow your rear from factory and I love their factory drum e brake.. Only Toyota makes the shoes still and the Toyota setup will allow any rear wheels to fit the back. If you upgraded brakes on s13 the hat sticks too far in and you have caliper clearance issues Share this post Link to post Share on other sites
WhoreMouth_Jr 0 Report post Posted August 9, 2017 I couldn't find that member on CSforums.com but I might just be trash at searching. I've been looking through a lot of old threads and this Photobucket shit is really fucking me up. All my rear wheels are similar sizing and offset, I would prefer to not have to get new wheels, so I would like to keep the track a similar to stock x7 as possible (I realize that with 0 chamber even if the track is the same it will be wider at the top) 16x9 +24/26. I know a guy with some a7/x8 rears but I can try and find 240 rears I imagine they will be more $$ Share this post Link to post Share on other sites
battleaxe 0 Report post Posted August 10, 2017 lol, i spelt wrong. heres his thread http://www.celicasupra.com/forums/showthread.php?102130-Slammed-Beater just go over a pros and cons list. aftermarket arms, diff options, availability of the subframe itself is usually the easiest as you only "need" one. i would think s13 anything in WA is suuuuper common. all our cressidas get junked and then crushed so the chassis is missing here locally. you also cant give parts away cause no one has them anymore. or theyre sitting under a tree and forgotten...the cressida curse. the x8 and s13 frames id have to imagine are quite wider than the x7/a6 frames. the benefit of custom is to raise the frame far into the chassis so your arms have good level no matter what. you also need to make towers as yours dont have them in the back, also another way to mod for full height usability. Share this post Link to post Share on other sites
Rue 0 Report post Posted August 10, 2017 I vote S13 rear with NA Z32 rear brake swap... has drum parking brakes that probably aren't plug and play but a start none the less... I'd imagine S13 rear subframe out of the wrecking yard would be easy and affordable Share this post Link to post Share on other sites
battleaxe 0 Report post Posted August 10, 2017 issue with the ebrake setup on the s13 is using the full knuckle as its integrated. i personally have this setup in my s13 and its amazing, but man i got lucky with the knuckle being complete. youd need the z32 and s13 knuckle and see how they get together. mine i think is s13 with z32 pieces bolted on. theres a weird nut that holds the whole back plate together with the lines and bits. the rears are the same on all z32s. the calipers in the front changed 3 times. the ebrake lengths are different from 2+2 and 2 seater. and i forget what i have as well. its a bit of a mess to make it all work and get all the parts. also, i dont believe the faces of the wheels will clear the z32 brakes on s13 stuff due to how far the caliper sticks out Share this post Link to post Share on other sites
Rue 0 Report post Posted August 10, 2017 Offset of stock Z32 16" rear wheels? Think about it more... and not using Z32 or S13 parking brake cables... shit in Nissan world goes together like Legos... I've put a couple together myself. Don't know what your talking about other than just talking... ***Edit... google came up with original rear Z32 setup being 16X8.5 +35... search Noob! People talk about the Z32 knuckle being an upgrade because it's aluminum but it creates other problems that must be addressed... stick with the S13 knuckles... KISS... Keep It Simple Stupid... it's been done a million times... nothing new Share this post Link to post Share on other sites
battleaxe 0 Report post Posted August 10, 2017 It's not all about size and offset, it has to do with the wheel face and how its spokes are concave, flat or convex. z32 wheels are quite convex and have a good arch to them to clear, obviously. Equips faces are typically quite flat and depending on what disc, depends on if they will clear the caliper protruding out.I used s13 knuckle with z32 plate. The problem isn't how they bolt together, its getting all the pieces to lego them correctly. Buying from a wrecker or a part out, you just need to know what to look for and make sure it's all there. Z32 rear brakes hooking up to the s13 ebrake is a matter of specific parts and then making a plate to connect the back half of the cables to the chassis and securing them someone to the subframe.I'm 100% keeping it simple, I'm telling him how many actual parts need to be sourced to make it work. Plenty of s13s out there that didn't bother with the ebrake portion and just did a hydro. I did the cable route. Its not hard, its just a pain in the ass when you dont know what to look for. I got lucky and bought an entire brake setup from a guy who had already connected the z32 plate to the s13 knuckle. all ebrake shoes and clips and tabs were there.I think you need to learn more about how many types of wheels there are and how the discs work as well as how those discs often change because the whole face of the wheel changes. like how a BBK face works vs a Low disc (big barrel).Example, a mesh wheel, very flat face, no matter the size and offset, they will not clear brake calipers that stick out beyond the hat. Many Nissan's have recessed hats and the calipers stick out past the hat. Creates a shorter track, and u can get wider wheels, in theory with a lower offset. Cressida's have a very far out hat and the caliper is waaaay back, so you can fit all kinds of flat faced wheels and not worry about caliper clearance. I thought this would be common knowledge by now. If you've been tinkering with toyotas your whole life I can see why you wouldnt understand this Share this post Link to post Share on other sites
WhoreMouth_Jr 0 Report post Posted August 10, 2017 I appreciate all the tips and suggestions seriously! Thanks for the link to that dudes thread as well. I'm super gay and would prefer if the OEM ebrake worked even if that required a custom cable or something, couldn't be that hard. Also 5lug is a must, I have still have to do a bunch of reading to see what parts would be needed to convert that over too if s13 route. I'm know literally nothing about nissans. I think I'm gonna one of each if possible and set them next to each other and compare and shit. Share this post Link to post Share on other sites
battleaxe 0 Report post Posted August 10, 2017 I should have a X frame once I go pick it up and I have my s13 frame also waiting for mods and can do the same. They're both bare frames though with no arms or axles etc so width issue wouldn't be able to be addressed Share this post Link to post Share on other sites
Gordo 0 Report post Posted August 10, 2017 Almost completely off the subject, and not intended as a redirect, but.... The Z33 rear upright (not sure where the 'knuckle' name come from) is also aluminum, and appears to have close to the same hook up points as the X8. What I wouldn't give to have aluminum uprights on the back of my car. Edit: This brain fart just moved my first drive date out about another 3 years Share this post Link to post Share on other sites
battleaxe 0 Report post Posted August 10, 2017 Almost completely off the subject, and not intended as a redirect, but.... The Z33 rear upright (not sure where the 'knuckle' name come from) is also aluminum, and appears to have close to the same hook up points as the X8. What I wouldn't give to have aluminum uprights on the back of my car. Edit: This brain fart just moved my first drive date out about another 3 years Why not setup the car and use it then re engineer the wheel? Share this post Link to post Share on other sites
Gordo 0 Report post Posted August 10, 2017 Call me Slammie........ But I am really not considering this. Just fucking with all of you, especially Rue, who is constantly giving me shit on my 7-year plan (or is that now 8?). Share this post Link to post Share on other sites
Rue 0 Report post Posted August 11, 2017 Nice 5 paragraphs of useless info... like most that you put up... master of the obvious with "spoke design also needs to be considered" No shit... "Somebody else figured out my Legos for me" Fucking faggot And Gordo... Who are you kidding... you're going to die and Alex is going to send your shell to Pick-N-Pull We're going to drive down and scoop all of your suspension shit out of the wrecking yard at a steal Share this post Link to post Share on other sites
Gordo 0 Report post Posted August 11, 2017 I've put in my will that the car, with all the 7M shit will get donated to Goodwill. So you can get it cheaper yet Share this post Link to post Share on other sites
battleaxe 0 Report post Posted August 11, 2017 ** angry fit about how to lego and then talking about lego lol,ok. Share this post Link to post Share on other sites
Rue 0 Report post Posted August 23, 2017 I sware the day I snap an axle I'm selling out and buying a jzx8! Share this post Link to post Share on other sites
WhoreMouth_Jr 0 Report post Posted August 23, 2017 Idk who said that but that guy is dead to me. Just got back from Turkey. The hunt for the subframe resumes Share this post Link to post Share on other sites
vampirebeats 0 Report post Posted September 20, 2017 https://youtu.be/-0jtoT0o5fI Meanwhile in v8 land Share this post Link to post Share on other sites
white_raven 0 Report post Posted October 8, 2017 if you have to change the floor pan out anyways why not just a do a live axle rear end like in the wagons? abundance of rear ends they are cheap and come 5 lug. https://portland.craigslist.org/mlt/pts/d/disk-brake-rear-end-88-ford/6325377774.html Share this post Link to post Share on other sites
ChriSOL 0 Report post Posted October 8, 2017 or he could do the thunderbird 8.8 irs rear w modifications to the subframe Share this post Link to post Share on other sites
Gordo 0 Report post Posted October 8, 2017 Didn't a couple of years ago, a member tried that, and promptly blew it apart ? Share this post Link to post Share on other sites
WhoreMouth_Jr 0 Report post Posted October 8, 2017 Joethehook did an 8.8 diff with beefed up axles But I'm pretty sure he still has the stock trailing arms with stoke hubs. Share this post Link to post Share on other sites
white_raven 0 Report post Posted October 8, 2017 so Joe used 8.8 irs diff with stock rear end? hmm that is an interesting setup. Share this post Link to post Share on other sites
