theianmonster
Ex-Chassis.
fuck you, it does need a jz. you ignorant bastard.
Sorry for the threadjack ian. Car looks good, but I still don't like how the avalon bumper looks with cress lights. Can you find some chasers?
I want to do a Cresta front end eventually, but anyways, the bumper needs to be trimmed more around the corners, there's that little lip on the bottom of the corner lights that its catching on.
And I have an extra steering rack.
lol. I wouldnt waste a JZ motor in this POS chassis.
I would do a JZ in a cressida if it is a super clean car. And it would probably be a single turbo but with an auto trans and probably not get drifted. But it would have to be lowered. fuel interior and no cage.
Disperse this talk into other threads.
Assholes.
Haha.
Beautiful Ian. I am really at a loss of what to do for your situation though. This whole VVTi 2JZ thing better be worth it because that BEAMS motor at Tiger sounds cooler even....... because it has an ECU!
I'm sorry, I just want you to be fast and happy.
Oh, and come to Barbeques at my house
If I get this 1JZ VVTi ECU from Brian that's a head in the right direction.
These are the parts I need:
Power Steering Pump
Tensioner Pulley/Bearing
Valve Cover Gaskets
DriftMotion Powersteering Line
ARP Flywheel Bolts
Header
MAF Sensor
Alternator
Harness
ECU
I already have my RIP Garage mounts and some shit already. Mark just gave me a crank pulley, two DriftMotion pulleys, and a no A/C belt.
I just want to get my 2J ready, 7M is getting old. This is the 4th 7M swap I've done in the past year and a half.
I think Lucas should donate all of this to you. He has a spare GE and a kind heart. nudge nudge.
Unless hes used up all of his love on me.
Bitches.
Fuck Bitches.
Get Money.
Also, front lip I'm working on, need to widen it an inch. No clue what its from.
I know, I know, I need to fit the bumper better. Need to trim more out around the corner lights.
yeah man once you get the corners sorted it will look perfect :thumbsup:
dood theres a bitch by your rear wheel, you wantin mo hoes fo the hoe down?
car looks snazzy and elegant almost haha
+6 on the lip you got
The whimsical elegant chariot emerges...
...and the clouds part for such excellence...
...the brave will wander the fields of imagination...
...creating the machines to unearth those whom talk behind backs.
...god i need some wheels...
Looks like I blew the headgasket tonight. Was driving it all normal and such, then the temp gauge spiked. Didn't think anything of it, because the cluster is bad and it does that. I tapped on it and it didn't go down. Got to a gas station, overflow was boiling and hissing steam. Let it cool down, drove it all the way home. It was boiling and hissing for a good twenty minutes before it stopped. Also, when I was driving I had the heater blasting, then at one point the heater went dead cold.
My buddy is coming over with a block tester tomorrow to see if I really blew it, either way, I need to get 7M's out of my life. This is number four...four too many...
Out.
i drove mine for a year with a leaky heakgasket that would seal up at operating temps until it finally gave up. mine blew doing 5mph pretty much iding through a residential street and went up in a plume of white smoke. couldn't even start up afterwards. went 1jz after that and all problems solved! hell i even got better gas mileage
