ryojikaji 0 Report post Posted December 2, 2008 No, I'm talking about the bolts on the front of the carrier. The X8 has 1 and the MK has 2. Can you show a pic of your mounts? My brother made his and I'm just curious to see how you did yours. -Matt-Panic! Share this post Link to post Share on other sites
Keith 0 Report post Posted December 2, 2008 Oh. Thought you meant four bolt on the cover like the Supra. I have the subframe cut & drilled for it but I haven’t mounted the diff yet. I’m just going to use some pipe stock as spacers to mount it up. I haven’t got that far yet but will shortly, I’ll post pics then. Share this post Link to post Share on other sites
aphxero 0 Report post Posted December 2, 2008 use roll cage tubing. Share this post Link to post Share on other sites
toycoma 0 Report post Posted December 3, 2008 stock supra LSDs suck balls. Share this post Link to post Share on other sites
Bill 0 Report post Posted December 3, 2008 make sure to get the diff angle spot on, mine shook like freaking mad over 100km/h when it was off a little. Share this post Link to post Share on other sites
Keith 0 Report post Posted December 3, 2008 stock supra LSDs suck balls. I'm sure they do. I have no intention of using it. Anyone have the measurements of the spacers to save me a little time? Otherwise I'll just eyeball it and shim/shave later as needed. Share this post Link to post Share on other sites
brian 0 Report post Posted December 3, 2008 read through this, its like 112 mm http://jzxproject.com/bbs/index.php?showtopic=478 Share this post Link to post Share on other sites
huckersideways 0 Report post Posted December 3, 2008 Those wheels look damn good on the car. The rest is just AWESOME. Share this post Link to post Share on other sites
Keith 0 Report post Posted December 3, 2008 read through this, its like 112 mm http://jzxproject.com/bbs/index.php?showtopic=478 Cool - thanks. Share this post Link to post Share on other sites
Bill 0 Report post Posted December 4, 2008 you can use something you know is 100% square on the face of the diff and it should point at the output on the trans. i used a long piece of hardwood that a checked for squareness, it's now my diff alignment tool. Share this post Link to post Share on other sites
aphxero 0 Report post Posted December 5, 2008 That old setup was temporary and had shitty pinion angle. I'll measure my new shit tomorrow it's perfect. Share this post Link to post Share on other sites
Keith 0 Report post Posted December 24, 2008 Something to look at... I need to finish cutting the excess metal out of a few more doors, but they are otherwise stripped. Front before/after: It has been unseasonably cold so I've been working on these in the basement. Heating the garage from -10F isn't going to happen. Front door weight: 54lbs off the car in OEM status 36lbs off the car, no wiring, window, power accessories & parts (except lock motor for ease of use), glass, etc. 5lbs front door glass alone Rear door weight: 40lbs off the car in OEM status 27lbs off the car, no wiring, window, power accessories & parts (except lock motor for ease of use), glass, etc. 3lbs front door glass alone Cheapo bathroom scale used. I wanted to get the front doors chopped out so I can get the NASCAR style door bars as far outwards as possible. Glass may or may not go back in. I want to put lexan in but that is a project for a much later date. Good news is that the windows are simple shapes and curves so it shouldn't be too difficult. Share this post Link to post Share on other sites
toycoma 0 Report post Posted December 24, 2008 I always want to do lexan but I gues it isn't that much savings worth doing. What is the lock motor?? I want to figure out a way to keep the window but just pull a pin or something to drop the glass down to open the window. Share this post Link to post Share on other sites
N.O. Drifter 0 Report post Posted December 24, 2008 ^me to lock motor must equal lock actuator. Share this post Link to post Share on other sites
Keith 0 Report post Posted December 25, 2008 Yeah. Motor actuator tomato tomahto. I will probably end up just using the glass for ease of use and obvious cost savings. Have a while to figure that stuff out. Saving 62lbs (or even 46lbs w/glass) total though, I'm pretty happy about that. Share this post Link to post Share on other sites
toycoma 0 Report post Posted December 26, 2008 You can lose the reinforcement bar in the door too if you plan on running nascar style doors bars on the cage. Share this post Link to post Share on other sites
Keith 0 Report post Posted January 8, 2009 It's a god damn miracle. Threw the motor in the bed of the truck last night and brought it over to a big Ford service/dealer shop. They handle all the 3/4/5 series trucks and stuff. 1,000 ft/lb of reversing torque, an ass load of CFM and a good 45 seconds of blasting later, the crankshaft bolt waved the white flag. Thanks to Ryan for hooking me up with his Ford mechanic. 1J maintenance & build resumes. Bought my rollcage tubing last week. Awesome cell phone pics from our cool local distributor: Wilford Brimley stacks that steel! Cage work begins next week. I managed to lose my subframe isolators and nuts. No idea where they are, not happy. Spindles painted. Drilling out strut towers and putting in coilovers whenever it warms up past the teens this week. It's 1 right now. I'd rather have it be -20. 1 is just depressing. First event: April 17/18 at GIR. Ugh...so much to do. Goodbye cash build, hello debt build. Share this post Link to post Share on other sites
Keith 0 Report post Posted January 20, 2009 After two days of trailer/car juggling, navigating snow drifts, black ice and Taco John's, the lead sled is at the shop. Cage begins. I'll be spending Thursday doing additional chassis prep while Ryan continues with the cage. Share this post Link to post Share on other sites
Keith 0 Report post Posted February 5, 2009 Taking our time, just finishing up details now. Complete pics to come. Share this post Link to post Share on other sites
toycoma 0 Report post Posted February 5, 2009 post the rest of the cage pics that you posted on ziptied. Share this post Link to post Share on other sites
Keith 0 Report post Posted February 5, 2009 I didn't post them. I'll have the car back home this weekend and then I'll take my own pics and post info. Share this post Link to post Share on other sites
Keith 0 Report post Posted February 6, 2009 Can't...resist....dimple....goodness. Share this post Link to post Share on other sites
Mats 0 Report post Posted February 6, 2009 that cage is a beautiful peice! Share this post Link to post Share on other sites
aphxero 0 Report post Posted February 6, 2009 WOW! Having money is nice isnt it? Share this post Link to post Share on other sites
Keith 0 Report post Posted February 6, 2009 Having skilled friends is nicer. Share this post Link to post Share on other sites
