toji004
'79 jzx32 SHAKOTAN ZOMBIE
well...im always open to a good trade...
it is my daily driver so ...
my old 1980 (the beige one) was done up by pj real quick before the car show and was parked in his little spot at TORC...oil cooler is from an fc...
mm fitment
i want 185/50s all around,either that or do 14x10's...meh, so i can get lower
MOST are solid i have hears of one IRS here in the states the rest are in AUS. and Japan...but yes,few did come w IRS fron the factory,but mine is SOLID :(
slight update
t3 weld on coilovers,rca's and s13 cusco camber plates...awaiting funds for koni yellows to install
new wheels within the month
plans on a 5mge swap+w58 hopefully within a few months and ill probably need a new rear end (mkI supra)
dope man, car has really transformed since i first seen it.
thanks guys...stil needs a lot of work but its getting there.
needs me a 1j now,and that means a new rear end and custom 5 link etc...someone buy my x6 so i can fund this.
did you have the x3 listed anywhere? i thought you were selling it too. hope not...
eh that was more of a feeler...no one offered anything near what its worth.
i love this one too much to probably EVER let it go...
big plans w little or no money = long term goals
hey, on zilvia, couple people are sellin blast pipes.
those wouild look cool on your car. tho i dunno about cops and 2 big shiny non resonated tips stickin out
dood, you could easily get an x7 wagon rear end if you're not dead set on the disc brakes on the rare mk1 rears.
plentiful and stout at 7.1" e-code
dam,n thats a good idea !!! it should hold up better to power than the mkI rear end also.thanks
ok found a place local Gspeed http://g-speed.sub.jp/l-e/ that ill be getting the 2jzge from non vvti(cheaper $500)
i need to get mounts from http://935motorsports.com/catalog/product_...roducts_id=1407
i need to somehow get that flywheel off of IAN !!!
dude, u can find 2jzge's at the junkyard often. cheaper. just got to put work into pulling it out with the harness and ecu, and rent their engine hoist over there in which they charge by the hour i think.
also sometimes some VVTI and non VVTI 2jzge's pop up on craigslist too.
"X3" has been added to the tech forum. why? because of YOU. :thumbsup:
wow,thats an honor in itself :)
only update so far is some 15x11 and 15x13-94 offset wheels...
searching for flares that'll fit em-ha
