ryojikaji
Wheel fitment bitches x8!
is it true that the stock springs of the s14 will fit our x8 chasis (specifically rx80 chasis) suspension? thanks for the info!!
Ton ton here from the Philippines! =)
Yes they fit but ure x8 chasis will bottom out fairly easily b/c car almost a 1000 lbs heavier than the s14.
17x9, +20 offset Rota IKR's all around with 215x45 tires. The fender lip has been folded so not to rub on the tires.
Guest 1_fly_asian
so i jus bought some wheels their size is 17x8 +45 anyone know what they would look like on the car
Guest tonllave
whats up rhett.=)
New wheels, 235/40ZR18 unsure of offset however they are made to suit the AUS BA/BF/FG ford falcon. Will measure them when they are off to get repaired.
fit perfectly...
(After rolled guards... And coilovers with -4deg camber...)
Lol
I'm getting these dirt cheap 18x8 +45 18x9 +45 I know its super weak but I'll run spacers. What sized tire would be good for these? Preparing for flamage
ive always used bolt on spacers. 30mm is the biggest ived used. dailied and drifted on them for like 6 months no problems. actually it was a 25mm spacer bolted onto a 5mm slip on spacer. pretty much i put the 5mm slip on over the studs, then put on the 25mm spacer and bolted it down. worked great.
Fronts: R33 GTR rims 17x9j et30 with 20mm spacers. I haven't touched the fenders. Tyres are 215/40's or 45's I can't remember
Rears: Rota Grids 18x10j et15. Fenders have been flared to fit and they rub a little on the inner lip part thanks to the JIC limp cock coilovers.
I need to stick my hand up my arse and pull myself together. Car has moved twice since April I need to get the interest back :-(
For what, the car? I honestly have no idea I bought it that colour. I can send you some more pictures if you like it looks green or blue depending on the light but it's no flippy colour. It used to be White so obviously it ain't a factory colour
And at auction:
Guest Mitto
Yeah I meant paint. If you don't know it's all good. I want something different but fitting for the age...
Guest Aweakling
Just got these pretty cheap off Craigslist. 235/35R19 on 8" +45. Not a fan of the centers so I think I'll rattle can them black to match the rest of the wheel. Now I really have to lower it. Just ordered new shocks to do the RAV4/A70 trick and I'm going to cut the springs a bit, all I can afford for now. FYI the Continental Extreme Contact tires they came with are amazing for the NW, pouring down rain and the road might as well be dry.
Guest Skitzo
Naice! Are you from Australia, and used to own a Holden Commodore?
Fuck they are pretty average.
Rota P45r's 18x9.5 +20 225/40/18 all around fenders pulled and rolled with fender roller iner hump hamerd in.had 245/35/18 on the rear and fit good rubs when going over shitty road bumps
on megan coils can go much lower also...
sorry i cant make the pics bigger
