ryojikaji
Wheel fitment bitches x8!
Thought id post this up for guys that wanna run lots of rubber. .
Specs.
-Stock bodied X8, rolled fenders (lips roled flat)
-SERIALNINE coilovers (80mm drop)
-Fr=19x8.5+30 (4mm spacer to clear coilovers) 245/35-19
-Rr=19x10+30 265/30-19
Remember these are 19's. . We are changing the fronts to 225/35-19 for much better fitment. . . . . So ya. .you can fit big tires/wheels. . just need pretty high offsets. . The front rims will prolly get a bigger spacer due to them rubbing the inside at full lock.
This is the car .
G.
g, did you use a fender roller? very nice and clean
Ya . . thats my specialty. . Mobile fender rolling. . $90/corner roll $130 roll/pull. .
G.
wanna vacation in NYC?.......i give you place to stay and home cooked west indian food! = )
i'm still lookin for someone around here that can do some clean fender work. but that 19x10 looks small compare to my worksl with the extra .5" ......then again i do have some stupid tires on there LOL
Seriously.. ? Gettin paid and Eating good food.. sounds pretty dope. .
I could get your Works on there NP. .
G.
What is going to take to fit some 17x8.5 +18 up front and some 17x9.5 +28 in the rear. Tires I was looking at 215/40-17 or 225/40-17 up front, and 245/40-17 in the rear..
^ not too much. for the front, a fender roller and some wheel well hammering. for the rear just a roll. can i recommend 215/45-17 for the front tho? and maybe 235/40/17 in the rear? either way you go its just a bit of work. nothing really intense.
oh yea, your also gunna need some negative camber all around.
Well, a 9.5j +32 I believe is perfectly flush. Seems like a big tire. 225 or 235 would be better.
Cool thank you... Neg camber would be nice but wearing out the tires is going to suck...
Thanx, I will get some 235..
work vs-xx
F 19x9.5 +29 235/35/19
R 19x10.5 +29 295/30/19
finally lowered it.......got sick of the basketball getting stuck under the car
im definately goin lower. still need to decide on tire sizes. and still gotta find someone who can roll my fenders and paint my car one time.
will i be able to clear 18x8.5 +35 and 18x9.5 +37 on an x8? what tire sizes would you guys recommend? if im planning to drop it on s14 stock springs what problems will i run into?
^ yes. no problem. 215/40 & either 235/40 or 245/35 on the back. roll the fenders a bit.
thanks feisar. im cool with dropping the car on the s14 springs without having to run tons negative camber?
Any ideas on how well this will fit 18x9 +30 front and rear front tires 225/40/18 should fit fine rears are 245/45/18 wondering if any one has any insite on the rears before i get the tires mounted ?
front is gonna fit weak. my front is 17x9.5+15 245/40/17 and rubs on big bumps in the road. 225 or 235 should be good. your inner fitment will be 9mm closer to the strut than i am, and i am CLOSE. 10mm spacer should fix both points.
definatly get no more than a 235 for the rear. my rear is 18x9.5+23 245/40/18 and rubs tons with my lowness. flatten the inner fender lip and you should clear just fine.
that is not an aggressive fitment at all. you can do better than that!
http://www.1010tires.com/WheelOffsetCalculator.asp
Holy fuck, those are huge.
Unless you like stock ride height or -6 degrees neg. camber, sell them shits to someone with a landrover, broheem. srsly.
Got two sets of 245/45/18 with 99% tread might as well use them . As for offsets I am not worried I have a fucking drawer full of spacers I am sure I will get proper fitment might have to get extened studs though. I like my lips flush with the wheel well not sticking out rather run more rubber if I can.
Got the wheels on today and the de 4x4 the front got some bald ass 245,40 18s in the rear on and some 225/40/18s on the front got some serious issues with rubbing though I gotta check out tomorrow fronts perfect fitment rear could use a 235/40/ 18 and a bit of a pull and a 10mm spacer sould be even with the front fitment then. Gotta fit my rear toe a bit with those wheels on fuck rear toes fucked one wheels toed in hard the others toed out hard no idea wtf this guy was thinking in Japan.
Took about 10min to fix it today fucking camber plate got knocked to positive on one side so I set them both to full negitive. Just have to bend the lip back in on the passengers side and then I can get a wheel alinement. 245/40r18s fit fine in the back are not rubbing even with the fucked toe. I think I might pull the rear a bit and thow in a 10mm spacer later on. I will post some pics up after I wash the car.
rayray:
i have wheels with the same specs as a set you were running and i have some clearance questions before i mount them while i have a fender roller borrowed.
specs are 17x8, 9 staggered, +30 front +29 rears. you were running 235's on the rear and 215's in the front... would i be okay running 225/245's rolling the lips flat on stock camber? how close were you to rubbing when you had this setup?
thanks
While reading and looking at all these beautiful wheels, I didn't get a exact answer I needed. I'm looking at 17" wheels maybe a 9" and 9.5" but can't figure what back spacing to go with. I will be pulling, hammering, and rolling the fenders, and don't want to run spacers also will be lowered with Megan racing coilovers. Can any of u point me in the right way. Wheels I am looking at 5 Zigen, Volk CE28N, or some CCW, these will cost some money so I will save.
