r2d2michael
2 many cressidas. a x3 build thread
figured i would start a build thread. most of the work has already been done so ill post some pics along the way.bought this 1979 cressida around 6 years ago bone stock. ran like dick and had this strange gunk all over the car. but was overall in pretty good shape for its age. 1st thing i did was convert to a weber 32/36 carb.
the carb:
https://postimg.cc/qtmT7hpv
http://20140309-184402-resized.jpg
then i started to get this gunk off. the original owner said he washed it with a concert cleaner of some sort. took a gallon of goof off remover and countless rags to wipe it off. then had serveral cutting and buffing layers done.
http://20140324-222132-resized.jpg
http://20140324-222139-resized.jpg
http://20140324-222152-resized.jpg
http://<a href="https://postimg.cc/dZ2NLpGj" target="_blank"><img src="https://i.postimg.cc/Rh8kbzFy/20140324-222210-resized.jpg" alt="20140324-222210-resized"/></a>
you can see where i had wiped off that shit. eventually it was kinda shiny.
http://20140403-222652.jpg
drove that for 6 months then a rod bearing said see u later
http://20140825-223857.jpg
bought another 4m and made a "good" out of the 2 that i had with a good head and good block
http://20140911-011437.jpghttp://20141018_190047.jpg
never put that one in.(probably would have failed anyway cuz i had no clue what i was doing) sold it to a guy with a 67 crown looking to upgrade from his 2m. i bought a few 2jzge's over the years but never put them in. i moved several times then finally had a good garage again. i then bought a vvti 2jzgte. added a s257xe borg, fuse fab manifold and a no name intake manifold.
http://20170917-005335.jpg
http://20171006-231313.jpg
basically swapped out all my suspension for T3 stuff along the way too.
http://20170916_200616.jpg
http://20170922_192125.jpg
http://20170928-201546.jpg
http://20171008_202926.jpg
wanted to keep auto but ended up converting to  a r154 using a OS Giken Super Single with movement alteration kit.
http://20171018_214808.jpg
had a 1 piece drive shaft made
http://20171104_192605.jpg
http://20171104_192617.jpg
used a mx83 clutch pedal and master. bolted right up. only had to make a top mount for the 3rd bolt location.
http://20190102_175611.jpg
http://20190102_175631.jpg
http://20190102_175650.jpg
put the battary in the back with disconnect and a fused relay for the fuel pump near fuel pump,
http://20180317_201714.jpg
used a PANIC wire harness with the link g4+ monsoon ecu
http://20180419_184259.jpg
wired up some gauges for the dash
http://20180419_184310.jpg
took the car to fuse fabrication for custom radiator,inter cooler,pipes,fuel cell,basically all the metal stuff.
http://20180213_214402.jpg
http://20180118-175010.jpg
http://20180710-190043.jpg
http://20180818_090313.jpg
http://20180818_090327.jpg
http://20180818-090335.jpg
i did practice on a 1987 x7 cressida that i traded my 82 corona wagon for. bought a gs300 2jzge/auto from a buddy that already had a panic harness made for a 87 x7. swapped that in and finished the other bits that needed to me done. drove that for over a year then sold to another buddy to buy yet another Cressida. sold it for 3500 and used that plus more cash to buy a 78 x3 from a buddy. was already na-t 2jzge swapped and 400whp. i put a interior out of a x6 i had (got smashed by a dude driving on the shoulder). done small things to it. was a good stepping stone to driving higher hp cars. Before i even started the 79 x3 i bought a 1990 corolla to learn 5 speed on. i had never owned or driven anything besides autos. i did have some experience on a bike but very limited.  after being confident enough driving that i felt like i could drive the 78 x3 so i bought it. driving the 78 x3 really got me motivated to finish my 79 x3.
http://20170126_220027.jpg
http://20170130_232303.jpg
http://20171029_135903.jpg
http://20180305_024717.jpg
http://20180307_194940.jpg
took the car to PSI in Portland for a tune after i got my wheels on.
http://20180713_194641.jpg
http://20180717_130108.jpg
http://20180717_132228.jpg
right now shes  at 475whp 400ish tq at 18psi.  currant projects are a for 8.8 rear end swap with better breaks
http://20190401_181019.jpg
http://20190304_185336.jpg
over the winter i did get all the front end stuff replaced : vvti gear,solenoid, filter and all needed gaskets o rings,  front main seal,cam seals, new water pump, new tensionor and pulleys. tried to replace the crank pulley with a fluidamper one but my lower cover has swollen and is rubbing. so ill put that one after i replace the lower cover.
http://20180729_142611.jpg
Got to ask, what ever become of that carb that was on the M ?
Looks like a couple parts catalogues.
That filter is a joke...what's going on there? Let that thing breathe
Hmm the whole next half didn't post lol I'll have to update it later
Gordo,  the OEM carb I sold with the 4m to the crown guy. Then another guy bought the Weber
Battleaxe,  I had that filter on the self so used it. I'm aware of the shityness of it. But she did make 475hp at 18psi with it on there.
Car is clean AF! Build looks great! Great job!
Should pick up covers for those pedals.  Get an extra one and trim your brake pedal to also accept one.  It's a game changer.  But I'm also probably the only idiot driving barefoot
WhoreMouth_Jr- i will do that at some point. im generally driving with my work boots on so i dont really notice.
i updated the post with more stuff as it didn't post the 1st time. when the weather isnt great i drive my 1989 x8 imported from Canada.
http://20181231_152525.jpg
its got 380,000 Km on a factory head gasket. digi dash,lsd and manual seat belts. its 100% stock. i have just done upkeep on it to keep it on the road in decent shape.
this is rad
Who made your 'bash bar' ?
Probably someone who is more concerned about the bumper than the car.
Good to see you post here Mike!
On 6/2/2019 at 11:11 AM, ChriSOL said:
kept the x3 steering box?
yes its stock for now. will swap to rack n pinon at some point. probably all x7 stuff
if your talking about the white x8 with full deck on the windshield then it was full deck and that one isnt mine.
