Gibbs
Lexus is300 Limp mode
so recently my wife overheated her is300 (bad radiator cap) and the car went into limp mode. i had to change all of the front seals on the motor anyways so i did that and put a new radiator cap on it, along with a new bank 2 sensor 1 o2 sensor, timing belt and vapor sensor as it was broke. None of this stuff has fixed the problem and the car is throwing no codes sadly any ideas?
car wont rev passed 4k and checked throttle already also just found it has a rattle in the bottom end coming off of revs....
do you have any pending codes?  the IS300 ECU is insanely sensitive to things.
im honestly thinking it went limp mode with the knock sensor due to bottom end rattle off rev's
