2jzcoupe
Family Truckster X83
This weekend the motor fired right up and runs really well so I happy since it was a unknown engine.
I need to get the tach working while searching here the link to do it was broken.
Also my temp gauge goes straight to middle on the gauge so I think the sensor may be the wrong resistance.
30554549557_a8c7f1da80_o.jpgUntitled by datsunguy1984, on Flickr
This should be the link, 2nd page those posts a picture of which thing to snip and replace with a wire.
https://jzxproject.com/bbs/index.php?/topic/2409-getting-the-tach-to-work/&page=2
If you are looking for an adapter I have a brand new msd box I'll never use.
oh, yeah super easy mod.  thought everyone knew it already haha.
Next will be getting my gauge to work.
I grounded the gauge and wired the sensor but goes straight to half when cold so that will be next after that tach.
You have both water temp sensors in the neck right?  2 pin for Ecu and the 1pin for the cluster?
Thanks for the how to on the tach I did end up taking it apart monday and remove said resister and now i have a functional tach.
I also was able to get the AC Comp wired and will check the function after getting a new radiator installed.
I bet it will be a chinaman radiator.....
i have a china OPL radiator on three of my cars... no problems yet.
I'd only recommend to remove the shit o ring on the drain...
I don't even stoop that low for my Datsun rat truck.
It just got a Griffin radiator, and it only cost $175.
US made, 100% welded, and available in a wide range of styles.
I had a brand new oem radiator in mine with strong dual electric fans and a proper shroud.. Running a 1UZ, not even anything turbo. After 4 hotlaps of Gingerman raceway the temps were already starting to creep up.. I switched to a Mishimoto and a Taurus fan and never looked back. Just make sure to use the stock radiator cap as the Mishi is junk.
I picked up a brand new oem cap and a new oem shroud clutch fan is fairly new also.
Maybe i will order a aluminum radiator jist for piece of mind .
Well its been a few months since my last post I got a radiator and new toyota fan shroud I have since put about 1k miles on the swap.
I also 3d printed a gauge holder for brian and zack and I.
I also fig out that trunk light covers from a ls400 are clear replacement for the doors
Then retro fitted some mk3 supra seats that feel great for stock seats and fit me alot better
Then I went for a Drive with fellow members Brian and Marc and they caused my r154 to lose gears.
Dont mind the wheels they are going away momentary fitment check.
That afternoon I had the trans out and now I am waiting on a rebuild kit to come in since they are on back order who knows when they will be here.
But then Today I had a pretty clean shell dropped in my lap Thank you Brian
So I will be swapping my stuff into the white car
Please for gods sake toss that Pyle radio in the trash while swapping chassis.
And fuck you Brian, I had dibs on that white one ya cunt. And you can’t ride in my shit either, apparently every car you sit in breaks
hey, i need that 😕
hey it wasn't a shell, it had an amazing 7m in it! 😂
No such thing......
like communism and friends with benefits, it is a concept that works on paper but not in practice.
