battleaxe
1JZ non VVTI PS Pulley
Just swapped PS pumps. put my oem pulley back on. the whole assembly has in and out play. the pulley itself seems to have some play in it as well. the bolt is tightened by having the nut tightened with a extension holding the pulley through the access hole.
is my oem pulley splines just worn? is it normal to have in and out play on that shaft?
mine has a little wobble aswell even when torque to proper spec or higher. every pump ive had does the same shit and ive gone through alot of ps pumps.
Didn't notice this, but no, not hydro. Also, I flipped my aluminum pulley I had around and it aligned correctly as the IS pump sticks out a few mm more than the 1jz's
