wesleyx62
93 2jzge lean code (code 25)
i keep pulling a code 25 fuel system lean on my 93 sc300 2jzge (in my 78 cressida). here is a list of things i have already check/tried
  • rebuilt ecu and have already tried swapping with a known good working unit.
  • new o2's (single wire)
  • re-calibrated tps
  • checked intake manifold and injectors for vac leaks (with brake clean while running)
  • new injectors (rebuilt)
  • i have a inline walbro 255 from summit
  • fuel pressure reads accordingly and doesnt fade after getting warm
im out of ideas and im looking for advice as to what i should be leaning towards now...
a few things i have considered but am not sure about:
  • walbro is external inline (my car came with a mechanical fuel pump on the 4m) possibly causing a pickup issue in tank as the higher pressure required from the new pump
  • iac vacuume routing incorrect. i need to find someone who has done a deleted egr and all other emissiosn related vacuume set ups like me.
  • i suck at building cars and should pick up gardening instead.
Thank you for any real help.
I think you found the answer...
But Wesley Crusher, converting a car from carb to EFI is not as simple as you think.
I suspect you are cavitating your pump due to poor pick up inside the tank.
And if you don't have the pump mounted level with the bottom o the tank, that makes it worse.
The tube in the tank was meant to feed what, maybe a whole 150 HP.
You are beyond skate boards, and building cars on Gran Torismo.
So if you can't handle it, try gardening.
give him props. he actually set up the cel. check for vacuum leaks again. these things arent that smart.
He probably doesn't even have the car any longer.
Holly fucking old thread bump....
