JimmyHoffa 0 Report post Posted July 5, 2017 I'm trying to get boost-by-gear working and I need to get a clean VSS (Vehicle speed signal) input to make it work. I do have a spare digidash gauge cluster I can smash open to reveal the answer I need, but I figured I'd ask around before wasting valuable 1980s shelf-parts. HOW MANY TEETH ARE ON THE VR/HALL EFFECT WHEEL THAT THE DIGIDASH USES TO TURN THE SPEEDO CABLE SPINNING INTO MPH/KPH Thanks homies. Share this post Link to post Share on other sites
WhoreMouth_Jr 0 Report post Posted July 6, 2017 I can't comment on the tooth count, but there is a speed wire that goes from the cluster to the the c1(pin 4 if my notes are still correct) body plug, I think it's pink. I think my tuner said he had to apply smoothing as it was pretty rough, but then again *sometimes* my speedo jumps around +/ 10 MPH haha. And he didn't actually do anything with that, it's just there for datalogging if I want Share this post Link to post Share on other sites
JimmyHoffa 0 Report post Posted July 6, 2017 I'm using the (I think pink) VSS signal wire that used to run from the digidash to the power steering control box, I just need to configure my ECU to make sense of the signal. Share this post Link to post Share on other sites
JimmyHoffa 0 Report post Posted July 7, 2017 2 pulses. VSS signal works and is accurate to a couple percent, now to figure out why the R154 gear ratios and my final drive ratio aren't triggering correct gear selection for boost-by-gear. Share this post Link to post Share on other sites
WhoreMouth_Jr 0 Report post Posted July 8, 2017 Here are my settings I think I have to adjsut it a little bit still, but like I mentioned nothing is really tying into speed haha. My tuner did boost by tps because I told him I would mostly be driftfagging my car *Edit oops didn't see that you had replied. Mine is in the wrong gear all the time haha not sure why Share this post Link to post Share on other sites
JimmyHoffa 0 Report post Posted July 10, 2017 I had to adjust my settings to get everything working properly. I set the VSS pickup to 2500 pulses/km instead of toothed wheel and adjusted tire diameter to actual in the TunerstudioMS Now the vss/rpm calculation works properly for gear selection. Now I just need to dial in my closed-loop boost control PID values and boost-by-gear will be mine. Share this post Link to post Share on other sites
