Dustin
When it's halfway out........start to giggle
Arg......
Maybe add some 57 buick exhaust ports on the fenders.
Progress is slow but I did pick up a RHD X7 steering rack. Probably the last bit I'll get until the beginning of next year.
Little shit that's been done.
Replaced the drain bolt on the transmission.
Plugged off one of the oil ports.
Oil feed
Oil return
Turbo mostly bolted up
And got the transmission bolted to the engine
Umm twin scrolls don't need dual gates, but since you have them....
What manifold?
If youre too lazy to go back through my whole 7 pages of a build thread, Im sure as fuck not gonna help you. You act like
I built the shit. I didnt. I bought it. It came with two. So back to my previous, I could cut and weld it into one, but why.........
Ill have to check next time I have the motor sitting in front of me. Got my oil return line. Ordered a 1/2" NPTF Female x 5/8" 37° JIC Swivel Stainless Steel fitting. Bored out the threads and turned down the OD to clean it up a smidge. After cutting the return line down to the correct size itll be welded together to make a solid piece.
Original fitting
B91_C7381_649_E_444_C_9258_7_AD2_C869872
Cleaned up
65_D9_C257_C0_A3_4_DDD_AD73_49_C69258079
Roughly what the end result will look like
39437_E6_C_ECDB_4_FF5_BF24_D54_F3_E194_C
You should have the fittings engraved "Hella-Done Right".
P.S.. I want that lathe.
Lathe almost fucked me down. Every lathe Ive ran has run of the diameter. This one ran off the radius. Took my first pass off the ID and had .080 to go. So I said cool, Ill take .040, .030, then .010 for my finish pass. Yeah not so much. Just glad I double checked after I took the first .040.
Cross slides that move to the radius, is old school.
Then they came out with ones marked to show diameter, for all the bimbos that can't multiply or divide by two.
Damn kids these days.........
i had this in my hands and was fondling and sweating on it for a while. i may have included some extra dna that you're gonna want to flush before you put this on your car, or you can just suck it out into your mouth.
As long as you weren't inserting it into your back side........
